Tool Talk Discussion Forum
another old compressor!!!
larry
10-30-2003 04:24:38
I am working on an old compressor that has very little info attached to it. It is a two cylinder piston type. The only markings on the unit are"L-19" The cylinders and crankcase are one single casting. A 1/8"(?) steel plate is held to the bottom of of the crankcase by eight bolts. The plate serves as the bottom of the crankcase as well as the mounting base for the compressor. The flywheel end of the crankshaft is tappered and uses a woodruff key and a nut to secure the flywheel/pulley. Each end of the crank is attached to the case using round cast iron supports that are attached to the case using six bolts. There is a "T" type manifold on both the intake and exhaust with large brass caps to block the unused part of the "T". The flywheel is cast grey iron and has suffered from abuse with some small chunks missing. It doesn't run real true. Any advice on how to true up flywheel??
The only other info is the tag on the tank. Tag has the name Metal Products, Savannah, Ga.
The compressor has two fill plugs but no drain plug. It appears that the unit will have to be tipped over to one side to drain the oil and refilled to the point of running out or the fill plugs?? INPUT PLEASE!!!!!
Larry
