Tool Talk Discussion Forum
arc welding aluminum?
Andy
10-29-2003 17:59:15
I am building wieght brackets for a pulling tractor. How would alum rods and my AC welder work on heavy alum,(I realize this isn't the idear way). I also have a 200 amp mig but it's DC and I don't want to get a tank of argon for a few welds. thanks, Andy
John K
10-30-2003 07:21:51
 Re: arc welding aluminum? in reply to Andy, 10-29-2003 17:59:15
If you need weight, why would you use aluminum for the brackets.
T_Bone
10-29-2003 19:14:38
Hi Andy,
You can also use a AL, AC electrode or gas weld with Acet/Oxy. You can use a piece of scrap AL from your drop off as filler rod.
Any AL welding process requires that the weld zone be kept extremely clean while welding. A new SS wire brush on a drill motor works well. Do a search on AL welding as I've written several articles on the subject on this forum.
I do however question your design usage. AL for a weight bracket?
T_Bone
Andy
10-30-2003 18:30:05
 Re: Re: arc welding aluminum? in reply to T_Bone, 10-29-2003 19:14:38
Thanks for the info T_bone. I will do a search. There are two reasons I'm using Aluminum: this is a pulling tractor and I want it as light as possible to make a light class and I found a 10' length of 3/4"X3 flatbar at scrap prices. Andy
