Tool Talk Discussion Forum
AIR IN WATER SYSTEM
lenray
10-29-2003 12:09:01
Have an 1 1/4 driven shallow well that my renter has been having trouble with blasts of air in the use of the water. I found that the air had leaked out of the bladder on the pump and had filled with water instead of air--usually this will I think be a water logged situation where the pump comes one everytime you get a drink of water. It didn't do that but would give sudden bursts of air to where it would knock a glass out of their hands. Is this condition because of the loss of air in the bladder????
T_Bone
10-29-2003 19:25:43
 Re: AIR IN WATER SYSTEM in reply to lenray, 10-29-2003 12:09:01
Hi lenray,
Usually a busted bladder will just short cycle the pump as it has no air left over, hence the water logged pump.
I would be looking for a suction air leak in the piping.
Air will rise to the highest point in a water system and collect there, then hyraulic out when the facet is opened.
You might also have three problems, one being the bladder tank and one being a bad pressure controller and one being a suction leak.
T_Bone
paul
10-30-2003 08:22:56
 Re: Re: AIR IN WATER SYSTEM in reply to T_Bone, 10-29-2003 19:25:43
That gets fun doesn't it, when several things are wrong at once? Think you fix something, & it still gives problems....
Remember my wood water boiler furnace with the weeping crack?
That front pannel must have gotten some real odd stresses - cracked in half a couple weeks ago, away from the original weeper.
--->Paul
T_Bone
10-30-2003 15:39:30
 Re: Re: Re: AIR IN WATER SYSTEM in reply to paul, 10-30-2003 08:22:56
While under pressure Paul? Even if not that had to be fun :)
T_Bone
