Tool Talk Discussion Forum
sleeve puller
Jim in NM
10-26-2003 10:37:13
Does anyone know where I might be able to buy a sleeve puller? I would like to rework a Farmall M for my Dad. Last time I used one was many years ago and the only brand name I can remember for one is OTC. Any help with this for a new or used sleeve puller would be very much appreciated.
Thanks,
Jim
Kennyp
10-26-2003 14:33:13
 Re: sleeve puller in reply to Jim in NM, 10-26-2003 10:37:13
Like others, I made one with redi-rod/all thread. If still in the tractor, place a jack on the floor and a 4x4 up to the bottom of the sleeve and jack til the tractor weight is helping. This was for wet sleeves.
Alvin n Ms.
10-26-2003 10:54:53
Some people say they use a welder to run a bead then knock the bushing out. Does aanyone know if that will work?
rustyfarmall
10-26-2003 12:18:41
 Re: Re: sleeve puller in reply to Alvin n Ms., 10-26-2003 10:54:53
What does that have to do with pulling sleeves?
Scott
11-21-2003 17:53:14
 Re: Re: Re: sleeve puller in reply to rustyfarmall, 10-26-2003 12:18:41
If you weld a bead around the inside of the dry sleeve the heat will contract it and it can be pulled or driven out much easier. Just make sure you don't weld trough the sleeve making it a permant part of the block! The same process works for bearing races that you can't drive out from behind.
RJ-AZ
10-26-2003 14:12:34
Alvin must be trying to say knock the SLEEVE out. I have done this on dry sleeved engines. I make sleeve pullers from ALL-Thread and scrap steel as I have never re-used any of the old sleeves. I knocked some sleeves out of a DT466 last week with a piece of 3/4" round stock. Dry sleeves can be a bear sometimes.
