Tool Talk Discussion Forum
Problems Welding thin material
Jaime
10-26-2003 08:40:01
We have a very basic arc welder machine and have problems welding thin materials, Any suggestions ?
Thanks in Advance
Chris
10-27-2003 09:46:32
 Re: Problems Welding thin material in reply to Jaime, 10-26-2003 08:40:01
Go to welding supply and get 1/6 or 3/32 7014 rods. These strike and run very easy. Set your welder at 35-40 amps, do a series of stitch welds letting it cool for a few seconds in between until its welded solid.
Paul Janke
10-27-2003 06:31:39
I have heard of using a second rod as if welding with gas where its main function was to absorb extra heat, but it also becomes filler rod.
art francis
10-26-2003 20:25:03
Use a torch & brase it using brass, works best..
Jailkeeper
10-26-2003 11:25:05
When you are welding thin metals, use low amp settings and a small diameter rod. Also, use a very short arc, meaning the tip of the rod should be almost touching the metal. Don't concentrate welding in one area, do a small area and move to another to avoid building excessive heat.
I have welded metal that was paper thin on cornhead snouts and have had excellent luck using the methods above.
Dave S.
10-26-2003 10:51:31
If you have a cutting torch, you can use solid wire and weld with that. Coat hangers will do in a pinch, but your local welding supply will have regular wire for that.
R. Marg
10-26-2003 09:31:16
use small rods 1/6 3/32 etc and very low amps or buy a 110v mig flux core welder they can be had for around $150 hope this helps you can also back the stuff you are welding with some thing like aluiniam etc some times that helps
