Tool Talk Discussion Forum
Bolts, with rounded heads.
Alvin n Ms.
10-26-2003 07:01:26
I have been looking at the craftsman sockets at sears, that claim to remove rounded off bolt head. I am talking about high strength bolts like you would find in tractors, dozers,and ect. I Would like feed back from previous users before I invest my wifes money. Thanks in advance, alvinnms
js
10-26-2003 15:43:52
 Re: Bolts, with rounded heads. in reply to Alvin n Ms., 10-26-2003 07:01:26
I bought a set of the sprial flutted impact sockets from sears to remove a couple of rounded off bolts on my disc mowers cutter bar. They worked excellent. They are not a gimick but a profesional product being carried by sears. i.e. could have bought the same thing off the snap on truck.
Greg(Mo)
10-26-2003 13:59:22
If they are anything like the set I have from Matco, they are well worth the money...so far, I've never failed to get a rounded bolt out with them. And as a flat-rate mechanic, they have saved my butt a couple times now!
rustyfarmall
10-26-2003 12:25:21
I have never used them, but they seem to be just another gimmick, marketed to the untrained, inexperienced, homeowner. I have serious doubts those things would be of any use to a real mechanic.
Alvin n Ms.
10-27-2003 09:55:39
 Re: Re: Bolts, with rounded heads. in reply to rustyfarmall, 10-26-2003 12:25:21
I have been welding a nut onto rounded and broken bolts. Is there a better way to remove a stubborn fastner.
Thanks, alvinnms
deereman
10-27-2003 11:57:15
 Re: Re: Re: Bolts, with rounded heads. in reply to Alvin n Ms., 10-27-2003 09:55:39
If you're going to be running into alot of broken studs, or rounded bolt heads, I would suggest getting a set of spiral extractor sockets. The old "welding the nut on " does work well, until you run into a tight spot that only a socket will fit. Just one of those things I've learned, wrenching on trucks & tractors the past 32 years
