Tool Talk Discussion Forum
Hay Elevator repair
lloyd
10-25-2003 13:08:48
My decripit old hay elevator, used for piling & loading firewood, just broke one of it's chains. I found replacement links @ TSC, but I can't figure how to pry the broken links apart to insert the new one. Is there a special tool, tricky technique, or is it jsut brute force. It uses #55 chain, if that matters.
Thanks in advance
ldw
Paul Janke
10-26-2003 08:56:52
 Re: Hay Elevator repair in reply to lloyd, 10-25-2003 13:08:48
When I need to repair the chain on my bale elevator which is being used for firewood, I usually first loosen the side with the broken link. The broken one is usually easy to pound apart. They slide out to the side. A second set of hands can be a tremendous help, because it is easier to use one big pair of water pump pliers with the jaws on each side of the link being replaced to pull enough slack to have the chain kinked so the opening lines up with the sides of the link it hooks to. Then as was said, you pound it into place. I try to put a piece of heavy flat iron in between the elevator and the chain so I'm not beating against the side of the elevator. It gets easier with practice, and if you do lots of firewood, you will probably get the practice. The whole job should take less than five minutes once you know how.
thurlow
10-25-2003 15:33:25
There is a tool (with different size slots) made to help hold the chain; you don't necessarily have to have one. Hold one link (on edge)on the edge of something solid (anvil, railroad iron); bend the adjacent link around so side lines up with slot in first link; rap it smartly with a shop hammer; reverse procedure to reinstall.....
