Help water with sand blast?
jjpalomo
07-06-2000 20:26:46
I have a hot water power washer of 2000 pse and 3
gpm, one of may customers want me to clean a brick wall of 30ft. height that is been painted red, questions:
1. i'm going to buy the attachment 30585 of Northerntools, i need to know if i use the machime that i have the pressure of the sand and water at this height will be affected?
2. I only have the hot power washer machime and the reguler gun that i use to clean with water do I need to buy a pot to put the sand, an other kind of gun, is my first experience with sand with water, could you please explaind me the equipment that i need to use in this cases and some tips to do this jobs? a millon of thanks
Wardner
07-12-2000 21:02:02
 Re: help water with sand blast? in reply to jjpalomo, 07-06-2000 20:26:46
OK, you have a five or six hp machine. If you are doing grafiti or only have five or six square feet total, go for it. Contrary to what you may think, underpowered machines will do more damage to the brick wall from joint erosion than a high capacity machine. Go rent a 250-375 cfm compressor and 600 pound blast pot and do the job right. Figure a minimum of $2.00 per square foot (because of the height). If you or the owner have lead concerns and/or need containment, you might need as much as $10.00 per foot. I am retired after 30 years in the business. I used 750 cfm and would get 1000+ square feet per hour working on the ground with no containment. I saw a lot of my competitors come and go because they never could understand that bigger is better.
