Tool Talk Discussion Forum
Difussion Pump
Slowpoke
10-21-2003 20:57:17
A friend has a metal cabinet about 18x18x8, containing an electric motor, belt driving what looks like a rectangular hydraulic pump, and a 2-1/2" verticle tube with a small diameter tube coiled around it, plus some other stuff. Someone has mounted a voltmeter in the center of the stick-on tag, so it's unreadable, but another tag on the verticle tube says Difussion Pump. What does it do and what other use can be made of it?
Tom R
10-22-2003 05:51:23
 Re: Difussion Pump in reply to Slowpoke, 10-21-2003 20:57:17
A diffusion pump is a type of vacuum pump. It is often used in industrial or laboratory environment in conjunction with a roughing pump to provide high vacuum for evacuation large chambers on accelerators, lasers, and high voltage multiplying chambers along with many other applications. For a brief description try the following site.
Link
