Tool Talk Discussion Forum
Craftsman Floor Jack
Don Thompson
10-21-2003 19:34:36
I've got a 3 1/2 ton Craftsman floor jack that pumps up to point of contact with item being lifted, then it drops all the way back down. Jack has only been used a few times in the two years I've had it. Any ideas about failure causes or repairs? Thanks in advance Don Thompson
Jeff
10-22-2003 17:46:01
 Re: Craftsman Floor Jack in reply to Don Thompson, 10-21-2003 19:34:36
You may want to check the fluid level and try pumping it all the way up without any load a few times. Be safe by always using jack stands.
Good luck.
Vern-MI
10-22-2003 03:46:39
It probably has metal debris in a check valve or rust or a bad check valve seat in the hydraulic pump. Solution is to disassemble, clean thouroughly, inspect check valve seats, balls, springs and O-rings carefully and reassemble with clean all weather synthetic jack oil.
