Tool Talk Discussion Forum
Plymoth Aclaim
wdTom
10-21-2003 18:22:25
Girlfriends Aclaim runs well, but lately it has been making a straing noise, most pronounced at idle. Sounds like a heat shield vibrating, but isn't. Seems to come from the right side or belt side of the engine, mayby between the the banks of cylinders, it is a V-6. Is like a rattle that fades in and out every second or two or three. Car has nearly 150 thousand on it, put a timming belt on it for her last spring, or fall, don't remember. Only thing I remember in this area was the water pump. But it doesn't seem to be leaking and it doesn't really sound like a bearing growling. Any ideas? Thanks for any imput here.
Craig
10-21-2003 22:20:05
 Re: Plymoth Aclaim in reply to wdTom, 10-21-2003 18:22:25
sounds like the water pump to me. my 88 plymouth voyager 3.0 had the water pump go bad. it made a knocking noise like a bad rod bearing. unfortunately it was actually diagnosed as a bad rod bearing on the #1 cylinder by a mechanic. since it has 220,000 miles i decided to drive it till it threw a rod. then it overheated because the water pump seized. i replaced the water pump and now it is as quiet as can be. However, i think the overheating damaged the headgasket. i'm still P.O.ed at the mechanic for misdiagnosing a water pump as a rod bearing.
i suggest that you and all other Mopar owners on this page go over to www.allpar.com and check out the forums. Allpar is the most informative chrysler related automotive site on the web. they have forums with great people that know alot about cars.
wdTom
10-22-2003 18:43:17
 Re: Re: Plymoth Aclaim in reply to Craig, 10-21-2003 22:20:05
Thanks, the web page looks interesting. Will probably be putting a water pump on soon. Wish I had done it when I did the timming belt, there it was if I remember. Worst part was getting to it.
Slowpoke
10-21-2003 20:36:59
It could very well be the water pump. It's recommended that it be changed when the belt is changed (60k), at least on the 4 cyl. I changed the belt at 100k on a 95 Neon 4 cyl and the pump jamed up at 135k, 60 mph, breaking the belt. Luckily, nothing else broke, as the 4 cyl is an interference engine. That means the pistons can smash up against the valves when the belt breaks.
The belt on my 89 4 cyl Acclaim broke on its own at about 120k , and now the pump has 138k on it. I guess it's time to change it.
The pumps jam up like they're welded!
