Tool Talk Discussion Forum
a-frame hosist support
pop
10-21-2003 07:36:43
I need a frame type hoist for my tractor shop, should support 2 tons,could be 10 wide x 10 hight, but don't what size members or steel type to use. Would use a lincoln stick welder to assemble. Any ideas ?
JMS/Mn
10-22-2003 01:09:11
 Re: a-frame hosist support in reply to pop, 10-21-2003 07:36:43
A few years ago I built a frame to support a 2 ton hoist, used it to put an 855 Cummins in a 2470 Case tractor. Overhead beam, 11 feet wide, was a beam with 12 inch web, 6 1/2 inch width. Supoorted on each side by 8 inch I beams, bolted on the bottom to 6 or 8 inch I beams, about 6 feet long, with homemade wheels underneath- made of 2 inch wide slices of 6 inch pipe, with quarter inch thick cookies inside with 1 inch thick hubs, 1/2 or 5/8 bolts in the center. I made the trolley that supported the hoist with front spindles from a Ford car- Taurus or smaller, but not a Pinto. Turned down the hubs in a lathe- they are the 'wheels' of the trolley. Welded the spindles into 1/2 inch thick plates which are the sides of the trolley. Pipes and bolts hold the trolley plates apart at the proper distance to ride on the overhead beam. Got the beams for 15 cents per pound, built the trolley for about $50, for bolts, plates, spindles, etc. Not over $100 in the whole project.
R. Marg
10-21-2003 08:28:52
sounds like you need what I cut up a year or 2 ago it was made of a pipe A frame on each end and a I beam between pipe was 2" and the I beam 6" I have 2 -6" 20' I beams for sale
pop
10-21-2003 14:41:05
 Re: Re: a-frame hosist support in reply to R. Marg, 10-21-2003 08:28:52
where are you and how much ?
R Marg
10-21-2003 15:47:01
 Re: Re: Re: a-frame hosist support in reply to pop, 10-21-2003 14:41:05
All I have left of it is scrap now but I do have 2 new I beams I want $75 each or $125 for both I'm at the lake of the ozarks Missouri
