Tool Talk Discussion Forum
residing barn w/menards tin
deano
10-21-2003 06:25:42
i'm going to reside gable ends of barn with steel. The old siding consists of tarpaper underlayment with a 12"X 24" roofing squares? They held up very well over the years, but woodpeckers punched holes all over it..Can i go right over the roofing material, or should i remove and install steel. the 1x pine planking is still in good shape underneath..The barn and siding are approx. 50-60 years old. suggestions?
Kevin
10-22-2003 14:45:19
 Re: residing barn w/menards tin in reply to deano, 10-21-2003 06:25:42
Well, the woodpeckers were after a lot of bugs to punch that many holes. I would investigate what kind of bugs myself. Carpenter ants would mean a teardown to the studs and do over...
Russ
10-21-2003 17:58:28
Have used some Menards tin with good luck. Use lots of screws long enough to get a good hold in the wood. I have pre-drilled a whole stack of tin on the ground, saves a lot of time putting the screws in!
