Tool Talk Discussion Forum
What Welding Helmet Buy
Anthony
10-20-2003 10:10:05
Hello,
I am looking to buy an auto darkening welding helmet. I do the occasional welding, not very much, mostly on an old backhoe, teeth, bucket etc.
My current helmet is not auto darkening, the lens is shot, and the plastic shieled is cracked. I don't know if it makes a difference, it is an arc stick welder. I don't know too much about welding, and I would like to know what is a decent helmet out their. I have seen prices ranges from $50 to 400 or 500 bucks for one.
I am looking to stay in the $150 area. I would appreciate any thoughts and comment.
Thanks.
Loren
10-24-2003 18:51:07
 Re: What Welding Helmet Buy in reply to Anthony, 10-20-2003 10:10:05
I got an Optrel about 5 or 6 months ago and it's done real good for me. Solar powered so there's no switch to remember(not a problem if you pick it up only once a month or so). I weld/fab for a living now and use it for a good part of almost every day. The adjustable tint is good for the low powered mig you may end up with, up to the high amp sticks. We run a 135 amp Miller on the low end up to the 500 or 600 amp Lincoln's and it is nice to be able to dial the shade you want. I have no complaints for the Optrel.
Moby
10-22-2003 19:20:44
A speedglass hood is the only way to go. They may cost more, but they are tops
Anthony
10-22-2003 14:13:40
Thanks to all for your thoughts. Don't know what I am going to get yet. Even though I don't do much welding, I don't want to find out when I am 60 that I could have taken care of my eyes a little better for 50 to 75 bucks more. When I have a chance I will look into these suggestions.
Thanks
Again.
BFO
10-22-2003 07:07:14
Save your eyes..... buy a Speedglass
Slowpoke
10-21-2003 00:11:58
You get more features when you pay more. Variable shades, larger view, better helmet, both battery and solar.
I got mine at Harbor Freight on sale for $120, down from $150 with variable shade, solar power and a view of 4x1-1/2. Add a full size view (4x5), better helmet, a replaceable battery, and the price would double. Battery is supposed to last 5 years, but by then they will be greatly improved and probably lower priced.
The first models out were $400.
Brian
10-20-2003 20:20:30
I used to weld at Deere in the early 80s, haven't done anything since. Never used this type of helmet but I am wondering why if you don't do anything that needs to be really tight tolerance or pretty work or use it very much- why spend so much?
Bishop
10-20-2003 18:45:07
I bought a auto one on EBAY for $75 with batteries. My Father-in-law, whos been welding for 40 years just bought a solar auto helmet at Harbor Freight for $60. Both work great.
Trucks
10-20-2003 19:43:46
 Re: Re: What Welding Helmet Buy in reply to Bishop, 10-20-2003 18:45:07
Right on Bishop, also something you might want to consider is a company called Accustrike,they have one that is a little different in that instead of auto darkening you open and close the shade by a strap on your chin, I don't know how good it would be, but on the plus side is there is never any batts. to buy and you could use any shade you want.Check them out at accustrike.com
Dave S.
10-20-2003 16:52:02
Bought one with the Hobart name from Tractor Supply for $175. Has the adjustable shade. Has a rechargeable battery and a small solar panel on it that will charge while your welding, or you can set it out in the sun for a couple hours to bring it to full charge.
wh
10-20-2003 10:16:38
Speedglass - get the adjustable shade/will cost around 250. bite the bullet and get it.
