Tool Talk Discussion Forum
Cincinnati Vertical Mill (Toolmaster)
Terry Clark
10-17-2003 19:33:40
I have an old 1959 model cincinnati mill and it seems to be stuck in high range I can't slow it down it has a variable speed pulley on it,I just recently bought it and am still figureing out what I have,and what I don't have.It has a high and low and neutral lever on the side,but when I change the selection it acts like it is not connected to anything,any help would be greatly appreciated.
Dave Doehler
11-02-2003 09:33:53
 Re: Cincinnati Vertical Mill (Toolmaster) in reply to Terry Clark, 10-17-2003 19:33:40
Terry,
It sound like you have a mill similiar to mine, model 1D. Service and parts manuals ($20.00) are available from Cincinnati Machine (www.cinmach.com). Parts are available from from them as well as Parts N Parts 1950 Berry Rd, Elida OH 45807 ph. 419 331 5658. I don't want to scare you but I replaced two cluster gears in the power feed gear box for the table at $1000.00 for used gears. Yur low speed pinion should be more reasonable. Good Luck!
Peter Alloway
03-28-2004 15:41:59
 Re: Re: Cincinnati Vertical Mill (Toolmaster) in reply to Dave Doehler, 11-02-2003 09:33:53
We have a toolmaster s/n 6J2F1AAF181 1973 model and with out manual, I wish to change the Draw bolt to Metric but do not know how to without pulling the head to bits.Can anybody help
Paul in Mich
10-21-2003 19:09:00
Terry, Hi and Lo range on those machines were accomplished through gearing. Variable speed was accomplished by transfering the diameter of the drive from the drive shive to the driven shive. If your machine has sat around for some time, the gears and shives could well be siezed in the position which it was last ran. you may be able to free things by local lubrication, if not, then you may have to disassemble the gear housing and the variable speed shives until they work freely.
Trucks
10-21-2003 20:45:27
 Re: Re: Cincinnati Vertical Mill (Toolmaster) in reply to Paul in Mich, 10-21-2003 19:09:00
I figured it out, and it out tonight I took off the motor and the top gear cover to find the gear responsible for low range is totally gone!!!!now I have to figure out where?who?How much? to get one from also looks like someone has been in there before some other stuff not exactly right.
John Garner
10-17-2003 19:57:19
Terry --
I suggest that you swing by the Practical Machinist bulletin board (www.practicalmachinist.com) with your questions. It's a great site!
John
Terry Clark
10-20-2003 19:46:09
 Re: Re: Cincinnati Vertical Mill (Toolmaster) in reply to John Garner, 10-17-2003 19:57:19
Thanks I beleive I will.
