Tool Talk Discussion Forum
How can I organize my shop?
Terry Clark
10-16-2003 20:11:42
How can I organize my 3 bay shop?I have alot of big stuff,in the middle of the shop I have a four post lift.I also have 2 BIG tool boxes,BIG air compressor,metal lathe,BIG cincinnati vert.mill,mig welder,stick welder,and a set of torches.Anybody with any pictures or a good floorplan?My shop is cluttered and I don't want to ger rid of anything.There used to be a section in HOTROD mag. called dreamcar garage it had pictures of a floorplan.any help would be appreciated.
Ron in Nebr
10-20-2003 20:34:00
 Re: How can I organize my shop? in reply to Terry Clark, 10-16-2003 20:11:42
In regards to the HOT ROD articles, I think I remember seeing where someone(maybe the HR guys themselves) put out a softcover book devoted entirely to shop design. You might try going to amazon.com and running a search for "shops" or something similar.
Trucks
10-20-2003 20:41:58
 Re: Re: How can I organize my shop? in reply to Ron in Nebr, 10-20-2003 20:34:00
Thanks I will try that.Terry Clark
RJ-Az
10-18-2003 10:59:24
I just moved into my new shop and gave the old one over to my wife for her storage. I have a 20x24 two bay open area with a 8x20 shipping container for secure storage. I found all sorts of thing I didn't remeber I had when moving. Also some things I had bought new and put up only to buy again cause I couldn't find it. Big deep shelve, overhead long term storage keeps plenty of open floor space. Here in sunny so AZ I can work out there 364 days out of the year. A piece of 4'x4'x1/2" steel plate wrapped around a 5"x5" steel tube upright for the vise,bench grinder,drill press and buzz box underneath. Made a tree with old 30p spikes for hammers, pipe wrenches and other tools.Also plumbed air,water and 4 elect boxes W/GFI onto this. Hung a 10" swinging overhead crane w/trolley and chain hoist
on this same 4x4.
Terry Clark
10-18-2003 15:08:01
 Re: Re: How can I organize my shop? in reply to RJ-Az, 10-18-2003 10:59:24
Thanks for all the good advice guys any more suggestions email me at [email protected]
jam
11-05-2003 09:35:47
 Re: Re: Re: How can I organize my shop? in reply to Terry Clark, 10-18-2003 15:08:01
the magazine "family handyman" has practical space saving ideas everymonth.
I use the ideas to free up more space for more stuff!!
good luck.
KEG
10-17-2003 07:25:25
I'll second Hal's comments: layout the shop to scale on graph paper, cut out scaled drawings of your equipment, place on the shop drawing in the manner you find most useful. I did this with my small woodworking shop (14x16) in which I placed a planer, table saw, workbench, jointer, bandsaw, and radial arm saw along with other side benches, cabinets and shelves. The process worked very well and my work flow was very good considering the limited space.
And one other thing. Equipment on wheels is the answer to many problems. You can get a mobile base that includes four corners and you cut 2x2's to make it fit the base of the equipment. It also comes with a foot pedal to allow it to move. When the foot pedal it up, the equpment is solid. But with the simple press of your foot, you can wheel it out of the way.
KEG
Jet9N
10-17-2003 17:15:04
 Re: Re: How can I organize my shop? in reply to KEG, 10-17-2003 07:25:25
Over the years I was involved in moving two manufacturing operations to new (larger) facilities.
I put a floor plan on a sheet of sheet metal and made scale models of all equipment with operators
space and maintenance space. These were pasted on
plastic refrigerator magnet material so they can
easily be rearranged without much effort. The magnets keep things in place if someone sneezes
and the whole thing can be carried without any
problems.
HTH
Jet
KURT (mi)
10-17-2003 02:06:06
If you have the room on your land you may want to put an addition on your garage. My 2 cents.
Slowpoke
10-17-2003 00:49:23
A year or so ago Successful Farming magazine published a special edition called "Farm Shops".
It showed photos of several shop interiors and some good ideas that people have used in their shops. But the shops are BIG, like 50x75. A county library may have back issues, or try this web address: www.agriculture.com/service. Check with your county extension agent for government publications.
Hal/WA
10-17-2003 00:11:28
I have a lot of "stuff" in my garage/shop too. And to keep peace in the family, I have to have things so my wife's car almost never has to sit out overnight.
I have workbenches along one wall and created a bunch of storage by building a 6 foot wide balcony over that bench wall. I hang a lot of smaller tools on pegboard, so they are easy to see and find. The other thing I have done is put lots of things on casters so I can move them around easily. I have a set of dollies with casters that fit under the wheels of a vehicle and allow me to fairly easily move a vehicle sideways for more room to work.
I have a heavy metal welding table just outside the bay door and usually do any welding outside or immediately inside the door. I hope to eventually add a large exhaust fan.
I remember the dream shop series in Hot Rod Magazine, and I think Car Craft also did one. You might be able to copy them if you went to a library that microfiches those magazines. The yearly indexes should be on the computer somewhere.
Another thought would be to do a map of your garage with graph paper and do arrangements your equipment with cutouts made to scale. The lathe may have to be really well held down to work properly, as should the large compressor, but much of the other equipment can and probably should be fairly portable. If you do mount equipment in a stationary location, plan for the maximum amount of clearance you will ever need between the equipment and another stationary object, like the wall. Under workbench storage is real handy for items that you don't have to have out all the time, especially if they are on wheeled dollies. I like the idea of having one bay as deep as possible, so you can work on long vehicles without having to leave the door open. But what works best for you in your situation might be very different than what works for somebody else's situation. And you will probably change your layout and keep changing it.
I hope to build another building that would be 90% storage, just to get rid of some clutter and to get some stuff that sits outside under cover. I also would like to have a separated area for a woodshop to avoid the sawdust problem. If I had it to do over, my attached garage/shop would be twice as big as it is. But that is not the way I did it and remodeling would be difficult. So I do the best I can with what I have and end up moving stuff around a lot. Good luck!
KX
10-17-2003 09:29:08
 Re: Re: How can I organize my shop? in reply to Hal/WA, 10-17-2003 00:11:28
Hal, I agree with your sentence "If I had it to do over, my attached garage/shop would be twice as big as it is." That is one I have heard and said myself over and over. I guess if I had a shop the size of a Wally World it wouldn't be big enough, I could easily find enough junk to fill it up.
