Tool Talk Discussion Forum
Plastic tank repairs
Freddie
10-16-2003 09:21:43
I've got a crack in a plastic gas tank on a 10hp walk behind Bushwacker. The crack is at the opening where the gas cut-off is screwed into. Has anyone had sucess with repairing, or sealing a crack in a black plastic gas tank?
The replacement tank is $53.
ErnieD
10-19-2003 16:37:52
 Re: Plastic tank repairs in reply to Freddie, 10-16-2003 09:21:43
IF it is a polyethylene tank it will probably be crosslinked, and can not be heat welded. It will have to be be fluorinated after the repair to prevent cracking. I successfully repaired a STIHL gas tank with JB Weld. You should use solvent alcohol or lacquer thinner to clean the repair area.
rhudson northern
10-16-2003 19:22:55
Northern has plastics welding kit i think its about $100. no cheap way out.
Bus Driver
10-16-2003 18:14:40
One point not mentioned is that the plastic must be identified as to the type before any repairs are attempted. Polyethylene and polypropylene- and your tank may well be one of these-can only be heat welded. Any filler used needs to be the same type as the parent material being welded. No effective adhesives exist for these two types. By feel and smell, I can identify most plastics, but words on a forum cannot explain the process.
Lil_Farmer
10-16-2003 15:44:41
Take the tank to a local body shop. They will have some two part adhesives used on ABS plastic body panels. If you can get them to do the job, it WILL hold.
Might cost you $10-15 bucks though, they have to mix a fairly large amonut just to get a little to use.
RobertTX
10-16-2003 10:52:30
I haven't tried it on plastic, but JB Weld would be a good shot and cheap.
Slowpoke
10-16-2003 11:38:06
 Re: Re: Plastic tank repairs in reply to RobertTX, 10-16-2003 10:52:30
I tried the "Goop" Household stuff on a white plastic gas tank and it only held for a few week before leaking. It says for plastic, but I think the gas killed it. I'll have to try something else. JB Weld does not specify plastic, but it could work.
Gabe S
10-19-2003 11:21:04
 Re: Re: Re: Plastic tank repairs in reply to Slowpoke, 10-16-2003 11:38:06
I have used JB Weld on a black plastic gas tank and it has held for two years. I know that this is not the ideal solution, but for me, it has worked. Good luck
Mac
10-16-2003 10:28:46
My opinion would be replace the tank, no headaches and money ahead in the long run.
ASE DUDE
10-16-2003 12:18:16
 Re: Re: Plastic tank repairs in reply to Mac, 10-16-2003 10:28:46
I'VE TRIED JB WELD AND IT WON'T WORK. SOMEONE TOLD ME ONCE THAT IT'S POSSIBLE TO "WELD" THIS BUT YOU NEED THE EQUIPMENT. YOU MIGHT LOOK IN JC WHITNEY AND SEE IF THEY HAVE ANYTHING.
Stick
10-16-2003 13:09:46
 Re: Re: Re: Plastic tank repairs in reply to ASE DUDE, 10-16-2003 12:18:16
Yeah, it can be "welded". Look for a place that builds plastic tanks, or a place that repairs ATV fenders.
