Tool Talk Discussion Forum
What is the handiest jig or tool you
ShepFL
10-15-2003 20:11:47
have made for your shop? I am talking about something you use regulary? Me, I don't have one so I am asking for some of yall's experience.
Been thinking of a portable welding jig that rotates and can be fastened down with C clamps.
Happy
10-18-2003 05:48:33
 Re: What is the handiest jig or tool you in reply to ShepFL, 10-15-2003 20:11:47
When I get some some time. I plan to weld a flywheel the the back side of the rotating shaft on my eng stand then on the leg of the stand drill a whole through it weld in a small peice of pipe. so i can run a shaft through it with a starter gear and handle on it. just to make rotating the eng a little easier
Terry Clark
10-16-2003 19:58:05
the handiest tool i've ever used is called a power probe.It is a must for any electrical work on cars,tractors,boats,motorcycles.Basicly,it connects to your batt.and you can test a circuit for +or- or you can put out +or- to the tip.costs around $60.00 off the tool truck.
john d
10-16-2003 19:46:36
Took the frame from an old weight-training machine and layed it horizontal instead of vertical. It's about 6' long, 32" wide, and 30" high in that position. Then I bolted three pieces of 2x6 across the top of it. On top of these I bolted a $39 set of steel ramps from Harbor Freight. This lets me use my other set of ramps to run the lawn tractors up on top and do service work. The tractor is at a height that's easy to work on, and everything is accessible.
The stand is very rugged, yet easily moved out of the way by one person. When it doesn't have a machine on it, I sometimes throw a piece of plywood on the top for additional temporary bench space.
Cliff Neubauer
10-16-2003 19:07:42
third party image
It doesn't get used all year but during the winter the best thing I have ever built is a used waste oil stove to heat the shop with. It isn't pretty but puts out alot of heat and cost almost nothing to build, it also gets rid of our used oil which is nice.
RogeR
10-17-2003 06:04:58
 Re: Re: What is the handiest jig or tool you in reply to Cliff Neubauer, 10-16-2003 19:07:42
Cliff;
I'm interested, too. Are plans available?
Thanks,
Roger
Richard Fazio
10-17-2003 05:53:51
I've been researching waste oil burners for a while. Ones I can build myself. How'd you do yours? Looks like you started with the barrel burner setup. What do you use to spray in the oil? I could really use one. I burn wood now but would love to get ride of my oil and make some heat.
Cliff Neubauer
10-18-2003 06:03:10
 Re: Re: Re: What is the handiest jig or tool you in reply to Richard Fazio, 10-17-2003 05:53:51
Guy's, the stove is really pretty simple. I started with the two barrel stove, then I took an old 100# lp tank, turned it upside down and welded in a 1 1/2" pipe nipple in it for a fill port (with a cap) and a 1/4" fitting for an air hose. I ran a piece of 1/2" black iron pipe through the side of the stove near the top that drips the oil on the fire. The oil is fed through a piece of old air hose through the original valve on the bottom of the lp tank but I need to add a needle valve where it goes into the stove for better oil control. This stove puts out alot of heat and you need to keep an eye on it because the oil burns really hot, I can get the sides of this stove glowing if I want but our 40x40' shop in not insulated so it takes alot of heat to keep it warm. If I was to do it over again I would try to find an electric pump to pump the oil so you could control the flow a little better, using air pressure was simple but the flow changes as the oil gets warm. Also it makes a very black smoke and soot but I think I may be starving it for air which could be causing that. Another key to making it work right is making sure the oil is clean with no water in it, with any water in the oil it won't burn right and if your shop drops below freezing it will freeze in the bottom of the tank. The oil storage tank should have the outlet mounted a few inches above the bottom with a drain for draining the water off the bottom. I have a few more pictures of it at the link below with a description of how I built it.
G. King
10-17-2003 13:27:18
40 years ago i saw a wood stove with a big steel plate 2"x10"x10"with used oil dripping on it one drop at a time. the supply was set near the heat to keep it warm . look like it was giving off more heat than just the wood.
Chris-se-ILL
10-17-2003 20:53:02
 Re: Re: Re: Re: What is the handiest jig or tool y in reply to G. King , 10-17-2003 13:27:18
My Grandpa made an oil stove similar to the one you describe. He used an old coal furnace type of stove and mounted a 1" thick steel plate in the middle of it. Then he ran a small steel line, from an overhead tank near the stove (there was a small petcock type of valve on the steel line), so that the steel line would drip right on the steel plate. He would build a hot wood fire in the stove to get the plate hot and then turn on the petcock valve on so that the oil would dip and then burn in the middle of the plate. After the oil on the plate started burning, it would maintain the heat and continue to burn even as the wood fire died out. I never saw the oil stove in use, but I was told how it worked. I have been tempted to try something like it though. I have "A LOT" of used oil that would provide me with a lot of heat.
p.s. I also heard that the oil stoves can make a real mess in the shop too, if they leak and smoke a lot! Maybe I will try it only on a very limited basis...
Fred OH
10-16-2003 15:05:45
A can smasher across the top of a barrel that crushes the can and the unit has the first 1 1/2" or so bottomless and as the can is shortened and the pressure let off...it falls out the bottom into the barrel. Made from angle iron, flat iron, pipe, six bolts and nuts and your imagination. First try...it worked perfect. Has angle iron sticking down on inside and outside for tightening bolts to barrel to hold it firmly in place. People who normally set empty cans around in your shop ALL use it and take the newbys to it and show them how to use it and say "Fred Made that". It doesn't need any braggin on...cause it didn't take that much enginuity to build...just necessity.
Another good project is to take 1/4" rnd. h.r. steel and make a "U" shape and weld several (you'll know how many) to a piece of light 1 1/2" angle or flat and bolt to underside of workbench to hang the combination wrenches on...can be size marked with a Dymo marker or felt marker after painting with alum. paint. Works fine for 1/4" and up as far as you want. Smaller end holds two or three wrenches each. Mount close to your wrenching area. Fred OH
TimV
10-16-2003 12:46:40
Interesting thread we've got going here--I'm already drawing mental blueprints for my own "hammer tree"! I'd say my best one is the mobile tool chest I made from an old cigarette dispenser--one of the white plastic jobbies with a bunch of shelves and plastic dividers for the various brands of cigarettes. I tore out the plastic dividers, screwed down plywood to the (sliding) shelf bases, and mounted it on casters. For around $20.00, I have a mobile tool chest that frees up a lot of wall space and lets me bring the tools to the work instead of vice-versa.
JoeK
10-16-2003 11:41:56
third party image
I do a lot of light grinding,wirebrush polishing etc.Built rotating stand to consolidate 6" grinder,bench motor w/course brush,bm w/fine brush and bench motor w/chuck into one unit,Top view shown,mounted w/sleeve on 3" pipe column with baler flywheel base.Motors are "cord switched" 4plex outlet has 25' cord to plug in.Motor w/3/8" chuck can handle sanding/grinding discs,cutoff wheels,buffers etc.Crossed steel plates are appx 8x30x1/4"
JoeK
10-16-2003 11:43:57
 Re: Re: What is the handiest jig or tool you in reply to JoeK, 10-16-2003 11:41:56
third party image
Rough base sketch
Errin OH
10-16-2003 07:10:41
Between shelves, cabinets, fixed tools, and work tables, I have almost no wall space left. A 4'x1/4" rod with the ends bent to form a really tall "s". I hang them on the truss's and the end is about 7' off the floor. That way I can route cords and hoses over head from stationary things like air comp, welder, tourchs, etc.., to projects without havin crap strung all over the floor. Also makes a handy handle when climbing down off something.
rustyfarmall
10-16-2003 07:05:09
A device for safely puncturing and then crushing aerosol paint cans. The puncturing part works good, I am still working on the crushing part.
ShepFL
10-16-2003 11:13:22
 Re: Re: What is the handiest jig or tool you in reply to rustyfarmall, 10-16-2003 07:05:09
Go out to your local Dollar store and get a can crusher. I have 2 of these. One is mounted in the garage for the soda cans and one is in the shop for after work barley pops. Simple camming action squashes the cans.
My sons then take the cans to the aluminum recycler and use the money to buy fishing bait or bb's for the bb guns.
rustyfarmall
10-17-2003 09:26:44
 Re: Re: Re: What is the handiest jig or tool you in reply to ShepFL, 10-16-2003 11:13:22
Have you ever tried to crush an aerosol paint can? If it was as easy as an aluminum beverage can, I would just put it on the floor and step on it.
ShepFL
10-17-2003 11:38:18
 Re: Re: Re: Re: What is the handiest jig or tool y in reply to rustyfarmall, 10-17-2003 09:26:44
Nope!
Generally, I just toss them in the fire barrel and let them go boom! Unsafe? probably but then I am 20+ miles from nowhere, fun - sure!
On the crusher I was just shooting from the hip. I do know that the "can crusher" will crush soup cans and those medium sized vegetable cans so I surmized it would crush an aerosol can releived of its pressure.
rustyfarmall
10-17-2003 13:18:27
 Re: Re: Re: Re: Re: What is the handiest jig or to in reply to ShepFL, 10-17-2003 11:38:18
I have it working now, problem was, I was using one of those tire irons, like comes with your car, for the lever to apply pressure, apparently those tire irons are made of some type of tool steel, and when I welded a bracket to it, the iron kept breaking right next to the weld. It works pretty good now. If only I could figure out how to make it all run with hydraulics. Oh well, another future project.
500sks
10-16-2003 06:26:21
Reversable Ratcheting wrenches from Craftsman or Matco. Once you use these it is hard to use a regular box end wrench.
Rick
10-16-2003 06:17:11
It is a mobile work bench, toolholder. It is wired for electric. has large vice. One of Handiest items have made. I also have welder and plasma cutter mounted on old dixon lawn mower frame. Roll it anywhere
Chris-se-ILL
10-16-2003 05:14:45
One of the things I made for the shop that I really like is a hammer stand.
I used a disk blade for a base, welded a 1" X 5' long black pipe to the base, to make a verticle pole. Then I chopped some 2.5" diameter thinwall pipe into 1" long cylindrical rings. I welded these rings around the pole at 3 different levels (tiers). This made a series of 3 levels of loops that stand out from the pole (like the petals of a flower), so that I can drop the handles of the hammers into the loops, (2 or 3 hammers per loop) yet the hammer head keeps the hammer from falling through the loop. The stand will hold A LOT of hammers! I set the hammer "tree" by the anvil and work bench so that I can just grab any size of hammer that I want and they are not all buried on the workbench.
TimV
10-17-2003 15:27:29
 Re: Re: What is the handiest jig or tool you in reply to Chris-se-ILL, 10-16-2003 05:14:45
Chris: Thanks for the idea--I had taken today off work to finish some outside projects up before snow flies, and had a bit of time to spare, so I made one myself. I had 2" pipe laying around, and I used an old car tire rim for the base. It works very well--I've finally got my hammers where I can grab them without digging through the pile!
Chris-se-ILL
10-17-2003 20:33:48
 Re: Re: Re: What is the handiest jig or tool you in reply to TimV, 10-17-2003 15:27:29
Hey Tim, I am glad that it worked out for ya! I have had a few more brain storms for the hammer-tree since I built it... I would like to extend the post slightly and mount a "swing-arm lamp" on the upper end of the post (run the cord down through the center somehow) so that I could swing the lamp around and out in order to aim it anywhere I am working near the stand (near the anvil and vise).
I have mounted a swing-arm lamp (attached to the wall) over my big tool box, so that I can illuminate my sockets and wrenches to more easily see the sizes (age plays heck with the eye-sight). I plan on mounting one near the drill press, and near the metal lathe too!
TimV
10-19-2003 05:55:37
 Re: Re: Re: Re: What is the handiest jig or tool y in reply to Chris-se-ILL, 10-17-2003 20:33:48
Chris: NOW YOU'RE SCARING ME!!!! I've been gone to hunting camp for a couple of days, and didn't get a chance to read your reply. As I'm setting on watch contemplating the lack of deer (there's plenty of deer, just not wherever I happen to set.....) the same idea came to me! I'm planning on trying it at some point, once I get a bit more time.
Chris-se-ILL
10-19-2003 11:47:49
 Re: Re: Re: Re: Re: What is the handiest jig or to in reply to TimV, 10-19-2003 05:55:37
Well Tim, if you do add a swing lamp to the pole... make the pole long enough above the hammer loops so that the lamp base does not interfer with the hammer's removal from the loops.
I tried something else too... I mounted a switchable "Power Strip" (with a 15' cord) on the side of a pole (that is attached to a base plate... looks like a hammer tree with out the loops!) and then put a swingarm lamp on top of the pole. This gives me 5 outlets (one is used for the lamp) that are switched and circuit protected. This I can move around the welding bench (the welding bench is a 3'X 4' movable steel table with grating on top and a very large vise) or into the middle of the floor area. The outlets are handy for grinders, drills, and such, plus I have a portable lamp that can be suspended over the area where I am working.
Indydirtfarmer
10-16-2003 02:56:16
A set of jacks/castors/stands/ect. that will fit any tractor that I've tried it on, that will let me SAFELY split a tractor, with no help. Not only do they work well in taking apart, but they are the greatest thing since sliced bread, when you start putting it back together. Both halves are supported, and are on 6" diameter, cast iron "crazy" castors.
RJ-Az
10-16-2003 17:15:53
 Re: Re: What is the handiest jig or tool you in reply to Indydirtfarmer, 10-16-2003 02:56:16
That reminds me, I better go get my splitting stands that I loaned out last summer.
Pat Molinaro
10-16-2003 10:36:50
Could I have the Indydirtfamer send a picture to my email for my neighbor who has to split his tractor for repair work Thanks, Pat
Dieselrider
10-16-2003 04:14:48
Could you post Pics.? It sounds very helpful.
TimC
10-15-2003 21:05:48
I scrapped out an old CO2 lazer from the hospital i work at and it had a vacume pump in it. I hooked the yellow hose of my AC gauges to it and the suction side gauge to a plexi glass plate. Apply a little grease to an intake or exhaust port and check for leaky valves.
My dad put a hydrolick jack on his engine hoist, welded a holding tank on, mounted a hydrolic pump and car battery for an easy way to lift rather than pumping that jack all the time.
