How long hose can I use?
jjpalomo
06-28-2000 18:49:59
I have a Hot Power Washer, 2000 psi, 5.5 Hp,
How long hose can I use it without lost pressure?
DHunter
07-01-2000 14:42:43
 Re: How long hose can I use? in reply to jjpalomo, 06-28-2000 18:49:59
The pressure loss will be porportional to the length of the hose. Even with a very short hose there will be some loss though it may not be noticable. I would rig up a pressure gauge at the wand end and while operating the pressure washer note the pressure at the pump and the wand at the same time. If you have a 50ft hose and the difference in pressure is, say 25 psi, then it'll be 50 psi for a 100 ft hose and 75 psi for 150 ft hose and so forth, assuming the hose is the same size from on end to the other. The smaller the hose the greater the pressure drop.
jjpalomo
07-06-2000 20:35:13
 Re: Re: How long hose can I use? in reply to DHunter, 07-01-2000 14:42:43
Thank you very much Mr. DHunter
Vern Graham
06-29-2000 22:36:13
When my son was building his house on the 5 acres next to ours we ran about 300ft of 3/8" air hose from my compressor (100 psi max)to his place to run an air nailer. It worked ok as long as they didn't try to nail too fast
jjpalomo
07-06-2000 21:27:33
 Re: Re: How long hose can I use? in reply to Vern Graham, 06-29-2000 22:36:13
Thank you very much, Mr. Vern.
