Tool Talk Discussion Forum
Homelite ST-155 string trimmer
J Roros
10-13-2003 10:19:47
I have a Homelite St-155 with the ZAMA carburetor. It turns over but it dies after a few seconds. Plug is new, new fuel lines, all screws have been tightened, and new gas. Anyone know what the problem could be.
Jim
10-13-2003 15:44:02
 Re: Homelite ST-155 string trimmer in reply to J Roros, 10-13-2003 10:19:47
If you have a hole in primer, that is a cause of it, you also will need to rebuild carb, put in a diaphram/gasket kit. You are not pumping enough fuel for it to run because your diaphrams are getting hard from possibly using alcohal fuel. Put a new bulb, diphram/gasket kit, spark plug, take the low and hi speed needle out, clean orifice, start, run, adjust, should solve your problem
Vern-MI
10-13-2003 13:27:07
What kind of fuel filter does it have? If it is one of those in-the-tank white round ones about 5/8" in diameter either clean by reverse flushing with carb cleaner or replace it.
J Roros
10-13-2003 14:21:52
 Re: Re: Homelite ST-155 string trimmer in reply to Vern-MI, 10-13-2003 13:27:07
I didn't notice any filter. There are two fuel lines going into two holes in the tank.
John in MA
10-14-2003 20:03:38
 Re: Re: Re: Homelite ST-155 string trimmer in reply to J Roros, 10-13-2003 14:21:52
The filter is on a weighted bob on the end of the line inside the tank.
John in MA
10-13-2003 10:46:54
First, check the spark screen in the muffler. If it's clogged,e ither clean it or toss it. If that doesn't work, rebuild the carb. It's getting to be the age where it needs it. These are inexpensive trimmers, but are quite reliable most of the time.
J ROROS
10-13-2003 14:20:22
 Re: Re: Homelite ST-155 string trimmer in reply to John in MA, 10-13-2003 10:46:54
I checked spark screen and it looks ok.
I found a hole in the prime bulb, would that cause the problem.
John in MA
10-14-2003 20:05:53
 Re: Re: Re: Homelite ST-155 string trimmer in reply to J ROROS, 10-13-2003 14:20:22
A hole in he primer bulb would cause gas to leak when you primed it. I doubt it would cause it to die after a few seconds, but it needs replacing anyway. Rebuild the carb as the next step. A kit is just a few bucks, plus you's need a primer bulb.
Xwired
01-03-2006 18:15:37
 Re: Re: Re: Re: Homelite ST-155 string trimmer in reply to John in MA, 10-14-2003 20:05:53
Ive the same trimmer, need a carb kit. It has a Zama but I dont see any number on carb. Think its a CU1 but not sure. Anyone know what rebuild kit to get?
ktmfresh
07-24-2006 19:14:09
 Re: Re: Re: Re: Homelite ST-155 string trimmer in reply to Xwired, 01-03-2006 18:15:37
Does anyone know where to get the rebuild kits for these trimmers?
