Tool Talk Discussion Forum
WATER WELLS
lenray
10-12-2003 14:13:38
I have put down a few 2inch water wells usually about 45-50 ft. deep and dropped the point down and put the check on top of the point.
When the 2 in. casing is down sometimes it will start to fill with sand and I can wash that sand back down but was working on one this weekend where I couldn't keep the sand out of the casing to get the point down.
What is the solution for the DO IT YOURSELF FELLA on these situations???
bill
10-15-2003 15:03:53
 Re: WATER WELLS in reply to lenray, 10-12-2003 14:13:38
Get a 2 to 3 hundred gallon water tank and a shallow well pump and pump water down the well. That should do the trick as you are not getting enought water volume down the well to keep the sand from entering the bottom of the well casing. good luck Bill
