Tool Talk Discussion Forum
Stuck old Lincoln welder
Hal/WA
10-10-2003 19:10:50
I broke my loader bucket today and needed to weld it to finish a job I am working on. I dragged out the sometime in the 1960's Lincoln stick welder that my Dad gave me and got ready to weld. When I wanted to change the amperage to a higher level, I found that the control is stuck. I put some fairly strong torque on the control, but it wouldn't move and I was concerned about breaking the plastic handle off. I did the welding at the lower amperage and it worked, but was very slow.
I don't weld all that often, but I am almost certain that the last time I used the welder I was able to change the amperage with little effort. I have a welding project that I plan to do soon that involves heavier metal and I really should be able to change the amperage to do that project efficiently. So I suppose I need to try to fix whatever is wrong. I never have had the old welder case open, so I thought I would ask what other persons on this board think the problem is and how I can fix it. Other questions: do I dare lubricate the mechanism, and what should I use? If I find that contacts have fused (welded together), how do I fix that and prevent it happening again? Thanks in advance!
John Ne.
10-12-2003 13:39:57
 Re: Stuck old Lincoln welder in reply to Hal/WA, 10-10-2003 19:10:50
I'd surely take it apart to check it out. Hereabouts, if something gets stuck or fails to work, half the time we find a big glob of mud dabber nests are sticking things up. An hour of work and you'll probably have it going again. John in Ne.
Fixed it!
10-11-2003 21:32:52
I took the back parts off the welder tonight and began tinkering. I found that for reasons unknown, the nylon (or some kind of plastic) spindle of the amperage control was stuck in its housing. I sprayed penetrating oil into both ends of that housing and worked the shaft back and forth with the handle and a pair of pliers on the other end. It took awhile, but finally it started moving. I hope the oil will be compatible with the plastic, but it's too late now! I also discovered that the control moves much easier if I pull out on the handle a bit while I turn it. It would not pull out at all before. The contacts looked OK so I just cleaned them up a little. I did note that all of the conductors and the transformer windings appear to be copper.
The inside of the case had about 40 years of accumulation of spider webs and dirt. I cleaned it all up and gave the fan motor a drop of oil. I also cleaned up the outside, which I don't think had ever been done before. It doesn't look new, but it sure looks a lot better than it did. Hopefully it will operate just fine for as long as I want it to and then I can give it to one of my boys.
Thanks to everyone who commented. I thought you might like to know what the problem actually was.
Bishop
10-11-2003 11:19:09
I got an old Lincoin Welder from a friend last year, the fan ran rough, until one drop of WD40, now purrs great. The main switch is sluggish but works. I took mine apart when I first got it, was full of webs and dust. Lots of screws and heavy to hand by yourself, but well worth the effort. Great machines at 40 years old. Mine had had a short out arc at one time, no damage, yours could be shouted out (Fused)at the control knob.
Farmer/Paul
10-11-2003 05:24:59
If it is a standard ( 20% duty cycle )Lincoln 180 or 225 amp AC buzzbox, you will probably find the contacts corroded together. You will have to coax the stuck contacts apart.With the machine UNPLUGGED I have polished up the contacts with emery cloth then blew everything down with compressed air.
Glen in TX
10-11-2003 00:03:53
You will have to take the cover off to find out what's wrong. Unplug it first of course. Compressed air and a good electrical contact cleaner will do wonders if used once a year on a welder. Some contact cleaner has a lubricant in it but a lite touch of lubricant or penetrating oil on the pivots of the rheostat switch will probably loosen it up. Lubricate the fan motor too if it has one while you're in there. Its that or take the welder to a auction and let someone else worry about it and get a new one.
