If you go to the Ford website, and follow the link to their commercial truck site, they have a towing application guide. Basically, its a chart of the max tow capacity for their trucks, based on model, cab (wheelbase), drive type (4x2 or 4x4), transmission and engine. A 3/4 ton pickup should be fine for a daily driver, just like a half ton (even 1-ton trucks can drive as smoothly as cars these days). A bumper-pull trailer should do the job for you. If you were going for more weight, a gooseneck might be a better choice. Since you want to tow, and are probably going to get into the 3/4 ton market, I would recommend going for the diesel upgrade and a manual transmission. The engine will add a lot to the price of the truck, but it should pay for itself many times over with fuel savings and less maintenance. I don't think you can go wrong with the Cummins engine in a Dodge. I'm not a big Dodge fan, but Cummins is tried and true. The PowerStroke in Ford's trucks (manufactured by International, if I'm not mistaken) also seems to be a really good engine. I've only heard one person talk abut the GM Duramax engine, and it wasn't good. Just one person's opinion, and I don't have any experience with them myself, so I can't really say for sure. The other thing I have to add is about the trailer brakes. I have never heard anyone, anywhere, say anything nice about electric trailer brakes. Usually, its a string of 4-letter words. For pickups, the vacuum-over-hydraulic system seems to be the way to go. I guess there's an electric-hydraulic system that's newer, but I don't know anything about it. The vacuum brakes will require a pump to be installed on your engine to create the vacuum. I'm sure it costs more, but you will have a trailer that stops when you want it to, without locking the wheels or fading out. Good luck with your selection.
