Tool Talk Discussion Forum
Home Sprinkler System
Bishop
10-08-2003 19:54:30
I just read the PVC posting and I was wondering if anyone here would trust the Home Sprinkler System?
It uses a PVC like pipe, and sprinkler heads like in business uses. We are going to build a new house next year and was impressed with the idea. Insurance Discounts?
DumOleBob
10-09-2003 08:17:59
 Re: Home Sprinkler System in reply to Bishop, 10-08-2003 19:54:30
I don�t think you could make a better investment to protect your family & property!
Can�t understand why people install underground lawn sprinklers and 4get the house�Daaaaa a???
david - OR
10-08-2003 22:00:09
Water is an incompressible fluid, and the shrapnel issue does not apply.
Home sprinkler systems can use a variant of CPVC; one trade name is "Blazeguard". Such systems are spec'd under NFPA-13D; this flavor of sprinkler codes is much more practical for a residential installation. There are a variety of sprinkler heads, including "invisible" heads that can be mounted above the ceiling. They drop down when activated by heat.
If you want the discount, the installation will likely have to be code complying. Your biggest obstacle is likely to be an adequate water supply. The worst-case hydraulic demand for a typical floor plan would be about 22 GPM at 30 PSI for 10 minutes. This is not a problem for city water, but if you are on a well you will typically need a separate storage tank and dedicated fire pump. The tank and pump will cost on the order of $5000 installed.
This is a pity, because the sprinklers and piping is relatively inexpensive. Figure on $1.25 to $2.00 per square foot installed.
There is no question that these systems provide a huge improvement in fire safety.
ShepFL
10-09-2003 12:47:25
 Re: Re: Home Sprinkler System in reply to david - OR, 10-08-2003 22:00:09
Ditto -
I did not have sufficient pressure and we could not afford the extra equipment. I have installed fire extinguishers in all rooms and we have practice drills from time to time.
buickanddeere
10-09-2003 07:58:16
I'm reto fititng my "new" 30 year old house. Using 3/4 copper and ball valves. Covering the high risk areas such as the kitchen, fireplace area, laundry room, family room Christmas tree area, garage, exit stairwells, bathrooms and the 2 of five accessable bed rooms. 3/4HP submersable pump test flows enough for one head. Will be enough to slow down or stop a small growing fire and allow more exit time. The alarm system has smoke,heat & CO detectors. Cheap safety/security for the family. Should be manditory in all new and retrofitted homes.
evielboweviel
10-09-2003 17:10:18
 Re: Re: Re: Home Sprinkler System in reply to buickanddeere, 10-09-2003 07:58:16
where are you buying your sprinkler heads at?
are they fast response residental heads?
Thanks
Ron
buickanddeere
10-09-2003 17:44:22
 Re: Re: Re: Re: Home Sprinkler System in reply to evielboweviel, 10-09-2003 17:10:18
The Mrs bought designer white heads at some fire shop in Toronto Ontario. Made by Central Sprinkler Company in Lansdale PA. Heads have #TY1334, 155F melt temp, residential and made for horizontal sidewall installation. The metering orfice is 1/4" dia which is smaller than the industrial units of at least 3/8"dia. Seen some 1/2" dia units too. Used 3/8" units when I was on city water in Toronto.
Joe in SW MO
10-10-2003 12:27:13
 Re: Re: Re: Re: Re: Home Sprinkler System in reply to buickanddeere, 10-09-2003 17:44:22
How about a garden hose reel in a kitchen cabinet loaded with 50 ft. of hose? Makes a poor mans fire supression system for remote areas.
buickanddeere
10-10-2003 12:40:09
 Re: Re: Re: Re: Re: Re: Home Sprinkler System in reply to Joe in SW MO, 10-10-2003 12:27:13
Hose doesn't work when asleep or away from home. Sprinkler keeps working too if the heat and gasses are too much for a human to bear.
