Tool Talk Discussion Forum
Verticle Shaft Engine
Slowpoke
10-07-2003 21:17:52
I have a 12 hp verticle shaft engine on an old riding mower with a bad tranny.. Is there any way to use the engine to drive a horizontal shaft generator or air compressor without buying a $300 right angle drive? I have read about people using old mower engines for such applications in "Farm Show" magazine, but it doesn't mention the type of engine.
Mark
10-12-2003 19:36:21
 Re: Verticle Shaft Engine in reply to Slowpoke, 10-07-2003 21:17:52
www.surpluscenter.com for cheap right angle gearboxes.
Slowpoke
10-12-2003 23:52:12
 Re: Re: Verticle Shaft Engine in reply to Mark, 10-12-2003 19:36:21
Mark... thanks. I looked at their boxes and the price looks pretty good. But I've figured out a way to do it with pulleys and a V belt. I'll get the bearings and shaft locally.
treeboy
10-08-2003 17:53:31
find someone who needs a vert. & trade for a hort,
the hor. engines usually are so different they are difficult to convert.. lots of bearings in hor.,, vert. is all allum. throwaway sleve type plus carb. problems.. find a mom & pop mower shopp
John
10-08-2003 14:45:19
I would be willing to bet you could use a beveled gear box from a Simplicity tractor. Go to www.simpletractors.com and ask the question there.
Van
10-08-2003 05:43:37
Yes it can be done easily, check out this site.
http://theepicenter.com/
tlak
10-08-2003 05:37:20
If you look at the new troy built riding mowers they use a horizontal shaft engine to run their direct drive trans and still have to change power to vertical to run the mower. How they do this is they have two free wheeling pulley that the belt bends at to change the direction to horizontal.
Richard Fazio
10-08-2003 05:23:15
A generator doesn't care which way it's sitting. I've made a 12 volt charger from alternators and small engines in both configurations. If your going to belt drive the generator it's easy. You could even use your mower base and make it easy to roll around.
Greywolf
10-08-2003 05:05:18
I puked out a horizontal on the rider and had a good vertical in another one. Motorshop said I could switch bases and use the good vertical one horizontally.
Maybe a small engine repair would have a trashed one laying around and you can convert it.
Opps...I'm assuming its a Briggs
john H
10-08-2003 05:14:28
 Re: Re: Verticle Shaft Engine in reply to Greywolf, 10-08-2003 05:05:18
you can't put a horz. base on a vert. engine or the other way round. if you stand a vert. engine upright the carb. stands up also and wont work.
john d - Well......
10-08-2003 19:15:18
 Re: Re: Re: Verticle Shaft Engine in reply to john H, 10-08-2003 05:14:28
....sometimes you can't, and sometimes you can. Depends on the make and model of the engine, how much time you want to spend, and how creative you are. When I used to teach the ninth-grade power mechanics classes at my school, we converted dozens of vertical shaft lawnmower engines to horizontal configuation over the years for use on minibikes, go-karts, small tractors, etc. The old Briggs engines were pretty easy, the Tecumsehs were harder, and sometimes we even used parts of one brand on another.
You have to pay attention to swapping/making a secure mounting base, the oiling system, the carb, and having a heavy enough flyweel when it's a small engine that mounted the blade on the shaft.
Slowpoke
10-09-2003 01:39:47
 Re: Re: Re: Re: Verticle Shaft Engine in reply to john d - Well......, 10-08-2003 19:15:18
Thanks for all the input and ideas.
Well, it finally dawned on me that I have a Roof rotary mower that uses a 9hp Honda horizontal shaft which turns a verticle shaft to run the blade. It's probably 30 inches from center to center on the pulleys, and the belt is just twisted 90�. But that's kind of long for other uses if things are to be compact. Reverse the system and a verticle engine can be used. The driven pulley must be below the mounting deck. I think TLAK has the answer, using two idler pulleys on a shaft. The belt follows an L shape and can be kept reasonably short and the driven pulley will be above the mounting deck. Belt tension can be adjusted by moving the engine.
Note to self:
Project # 1052: Build engine driven air compressor
using old riding mower.
