Hyd pump shaft seal
scott
06-25-2000 18:34:42
I'm having a hard time trying to install the new shaft oil seal in the hyd pump of my AC 160. I've tried freezing the seal, using a socket and with/without the pump shaft installed in the casing. It seems as though the seal is ever-so-slightly too big for the casing. The seal fits the shaft fine. I've replaced oil seals before and not had a problem other than being careful to allign the seal straight so it doesn't cock. I would appreciate any help/tips. The seal is new from the AGCO dealer. The Hyd pump is an Airequip with an aluminum casing. Thanks.
