Tool Talk Discussion Forum
A- frame hoist
Ty
10-03-2003 19:33:25
I want to put a A-frame hoist in my shop. I have an electric 3 ton hoist to mount on it. I want to make it 12' high and span 14'. I'm going to mount tracks in the floor so it will roll from one end of the shop to the other. What I would like to know is how big of a beam would I need to span 14' and hold 3 tons in the middle. I want to build it heavy enough but not over build it too much so that it is too heavy to move around.
RJ-AZ
10-05-2003 19:25:13
 Re: A- frame hoist in reply to Ty, 10-03-2003 19:33:25
I am using a 8" wide x 12" tall I-beam supported by 4"x4" 1/4" wall legs and some 4" steel casters that I salvaged. I have a 2 ton chain hoist on it and it has lifted all I needed. The casters could be better but the price was right. The beam was salvage as were most of the 4x4 tube.
Jerry A.
10-05-2003 17:30:20
You might be able to get some info from a steel supplier re: the technical numbers for the calculator suggested in the other post. I worked with an engineering type that ran a top notch machine/fabrication shop that also sold steel. He helped me to determine the correct size of steel beams for my new home. I learned a lot from that experience.
Ray,IN
10-04-2003 21:22:39
You may figure this for yourself at this website. Scroll to bottom of page.
