Proper way to shift 801 Ford Select-o-speed?
Herb Wheeler
09-12-1998 15:27:09
I just purchased an 801 Ford with selecto-speed transmission. My question is do I need to push in left foot pedal when shifting to higher or lower gears? Or do I just move shift lever? I understand it would be necessary to push in pedal if I'm changing directions. I can't read decal on the tractor on shifting it. Thanks for any help..
clyde
09-12-1998 20:05:11
 Re: Proper way to shift 801 Ford Select-o-speed? in reply to Herb Wheeler, 09-12-1998 15:27:09
: I just purchased an 801 Ford with selecto-speed transmission. My question is do I need to push in left foot pedal when shifting to higher or lower gears? Or do I just move shift lever? I understand it would be necessary to push in pedal if I'm changing directions. I can't read decal on the tractor on shifting it. Thanks for any help..
just move the lever at lower engine speeds But push pedal down when at higher rpm or you will be jerked of the seat. or the tranny will go out
