Tool Talk Discussion Forum
Need a Cold Glue/weld for steel
DumOleBob
10-01-2003 18:32:18
I need to attach three sheets cut from 12 ga mild & stainless steel on top of each other � sandwich style � without using
heat , (e.g., as in welding) as all three will be finished.
It would be fine, even helpful, to maintain a gap between the sheets to help create a 3rd dimension. Ultimately, the piece will be wall mounted using screws through all three pieces. Till then I need to hold them together.
What could I use: JB Weld, epoxy, exotic glue, horse manure what, what what???
wolfe in tx
10-02-2003 23:24:06
 Re: Need a Cold Glue/weld for steel in reply to DumOleBob, 10-01-2003 18:32:18
liquid nail from the local hardware store will hold it i use it to stick stainless steel to walls all the time it will hold it
MarkB
10-02-2003 16:07:07
Another thought is to use a urethane adhesive. 3M 5200 is an excellent adhesive/sealant intended for marine applications. It doesn't stick quite as well as epoxy, but it has excellent flexibility and gap filling properties. It's similar to silicone, except that it actually sticks. Also, you can get it in white or brown, if you care about the color. You can buy it at any marine hardware store for about 8 bucks a 10 oz tube.
Randy
10-02-2003 10:36:35
Get some of the money from aicha in the post below and hire the job out.
T_Bone
10-02-2003 09:38:59
Hi bob,
The gap your wanting would be a problem with using caulking. Butyl is much stronger than silicon but with a spacing between plates would be very weak.
Epoxy would be the next choice as the final adhesive. I would use a 5 minute super glue to pretack all parts together giving the epoxy time to set without movement.
The SS would have to be extremely clean of oils, alcohol cleaner, with deep cross hatching where the epoxy is appiled as this would give the epoxy someting to grab too.
Hilti makes a epoxy for there concrete anchor inserts, so that may work well.
There is also a pressure bonded epoxy that sets as pressure is applied. I never used this stuff so can't tell you anything about it.
I would consider using two types of epoxy as over time the hard set epoxy will seperate where the soft set epoxy would be flexable. UV might be a problem if in the sun.
You might also want to consider using SS pins for the offset strength with the pins being epoxy fasten. A slight blind hole in the plates for the pins. This would hold well for vertical shear strength. A end mill bit would work for the blind holes.
T_Bone
Dumolehayseed
10-02-2003 05:36:26
I gots to know why you are doin this and what there goin to be doin there on the wall.
MikeM
10-02-2003 05:25:42
Check with a local Auto Body Shop supplier as most new car panels are held together with epoxy. Maybe someone at a body shop would let you use some they have. Most is made to use a special caulking type gun and they have a mixing nozzle
very fast and easy to apply where you want it.
aicha
10-02-2003 08:34:43
 Re: Re: Need a Cold Glue/weld for steel in reply to MikeM, 10-02-2003 05:25:42
Dear ,
Good a thing to write you .
I have a proposal for you,this however is not mandatory nor will I in any manner compel you to honour against your will.
Your profile pushed me to send you this mail,I am
Aicha Mecca,21years old and the only daughter of my
late parents Mr.and Mrs.Sheik Mecca.
My father was a highly international reputable businness magnet-(a cocoa merchant) who operated in the capital of Ivory coast,Abidjan during his
days.
It is sad to say that he passed away mysteriously in
Europe during one of his business trips abroad year
12th.Febuary 2001.
Though his sudden death was linked or rather suspected to have been masterminded by an uncle of his who travelled with him at that time.But God knows the truth!
My mother died when I was only 4 years old,and since
then my father took me so special. Before his death on
Febuary 12th 2001,he called me who accompanied him to the hospital and told me that he has the sum of twenty two million,seven hundred thousand United State Dollars.(USD$22.700,000) compiled in two metallic trunk boxes(Consignments) and deposited with one of the leading security company in Europe.
He further told me that he deposited the consignment in my name,and finally issued a written instruction to the security company whom he said is in possession of all the necessary but legal documents to this consignments and the security company .
I am just 21 years old and a university undergraduate
and really don't know what to do,this is because I have suffered a lot of set backs as a result of incessant political crisis here in Ivory coast.The death of my father actually brought sorrow to my life.
I am in a sincere desire of your humble assistance
in this regards to help me travel to europe and clear the two trunk boxes while I forward you all the necessary
but legal documents that back up the deposit of the consignment.
Now permit me to ask these few questions:- 1. Can you honestly help me as your daughter? 2. Can I completely trust you? 3. What percentage of the total amount in question
will be good for you?
Please,Consider this and get back to me as soon as
possible. Through my private email box bellow for
security reasons:([email protected])
Thank you so much as you read this mail comprehensively
and get back to me.
My sincere regards,
Aicha Mecca.
Badger
10-02-2003 03:42:04
I'd go with clear silicon caulking, paint won't stick to most silicon caulking so be careful around the edges if paint is going to be used.
DumOleBob
10-02-2003 07:14:11
 Re: Re: Need a Cold Glue/weld for steel in reply to Badger, 10-02-2003 03:42:04
That makes me wonder if the silicone will then NOT stick to a painted surface - I guess not???
Mac
10-02-2003 10:50:56
 Re: Re: Re: Need a Cold Glue/weld for steel in reply to DumOleBob, 10-02-2003 07:14:11
silicone ought to stick to well cured painted surface. Only thing I had problems with was if surface was oily or certain types of plastic Like used on automotive interiors.
Nolan
10-02-2003 03:25:09
Also urethane glues are pretty adhesive like in their properties. Not flexible like contact adhesive though.
MarkB
10-02-2003 02:59:38
I'd probably use WEST System Epoxy. This is a thin epoxy intended for boatbuilding use, but you can thicken it for other applications. You have choice of fillers to use, depending on the application.
You can get WEST System products directly from the manufacturer, Gougeon Brothers (see link), or from most marine hardware stores. I generally buy from Jamestown Distributors, www.jamestowndistributors.com.
TimC
10-01-2003 19:32:32
Contact cement applied to both sides and allowed to dry then put together and you would probably have to destroy it to get them apart. Like applying formica for a counter top.
Maybe...GE silicon II. You would have to have a press to evenly press teh peices together then wipe off what squeezes out. Allow to dry and they won't come apart without a fight.
Dumb Bob Caesar
10-02-2003 00:07:56
 Re: Re: Need a Cold Glue/weld for steel in reply to TimC, 10-01-2003 19:32:32
Is that your name Dum Ole Bob?
