Tool Talk Discussion Forum
electrolysis
david
09-30-2003 06:39:05
Hi guys. Saw an article yesterday about electrolysis. Can anyone explain this a bit more and how to do it to clean parts
Jailkeeper
09-30-2003 19:44:30
 Re: electrolysis in reply to david, 09-30-2003 06:39:05
Here's a good description with pics. and plans to make your own.
john niolon
09-30-2003 16:57:24
David,
there has been an ongoing discussion/experiment on the Hobart site... some real good info there..
hope it helps
john
http://www.hobartwelders.com/mboard/showthread.php?s=&threadid=1976&highlight=rust+removal
Jerry A.
09-30-2003 14:36:07
Try:
Link
for starters.
r_d97
09-30-2003 07:02:32
David,
You need to do a search in the "Paint & bodywork" grpup as some of these guys live and breath this method. Real good discussions and experience in that group.
Edward
Bob G
09-30-2003 07:02:09
I've used it a couple of times to clean up rusty parts. You get a plastic tube big enough for your part you are cleaning to be submerged. Fill it with water and add some washing soda, baking soda will work, but not as well. Use a bar across the top of the tub to bolt or tie a chain to that can also suspend you part in the water. For the electrode I use a piece of rebar, connect the positive side of a battery charger to this and the negative side to the chain suspending the part. It will start to bubble and foam and pull the rust to the piece of rebar. The part will end up with a black coating on it. I then dry it with air, prime and paint. The more power that your battery charge has the faster the part is cleaned.
Bob
