Tool Talk Discussion Forum
Clutch Pilot Tool
Slowpoke
09-28-2003 01:25:08
I was offered (for $8) a clutch pilot tool set consisting of a long tapered cone sliding on a 1/2"x8" shaft with several sizes of screw on pilot tips. The largest tip diameter is 1". Is that large enough for clutch installation on tractors like Ford 9N, Case VAC, IHC 350U, AC WD45, etc? I have not worked on any clutches yet, so I don't know what size the pilot bearing holes are.
Thanks,
Slowpoke
Jerry/MT
09-28-2003 12:57:57
 Re: Clutch Pilot Tool in reply to Slowpoke, 09-28-2003 01:25:08
I replaced the flywheel on my TO-30 and the pilot bearing I.D. was about 1/2" - 5/8" to my recollection. I've never seen them be much bigger that 3/4" but you can never say never! The kit you have should work on most of the equipment you described. And for $8 you can't go wrong.
Tractor Dan
09-28-2003 06:15:54
its a good deal grab them up even if they are to small i have wraped black tape around them to make them work
Tom
09-28-2003 04:47:30
Slowpoke, get it. You can't go wrong for $8.
RickB
09-28-2003 04:19:03
The tractors you list that I know, and I suspect the others as well, have pilot ID's of less than 1". Remember that universal clutch tools may have limited value when installing double clutches.
Slowpoke
09-28-2003 19:54:12
 Re: Re: Clutch Pilot Tool in reply to RickB, 09-28-2003 04:19:03
Thanks to all for the answers. I'll get the set, and hope I don't have to use it!
