Tool Talk Discussion Forum
Truck fuel tank?
Mark Kw
09-27-2003 07:21:20
I'm in the process of converting the 3/4 ton Chevy my wife gave me into my small service truck. Has a 6.2L diesel with dual tanks. I'm removing the p/u bed and going with a custom built body which will have a drop down area on the streetside directly behind the cab to accomodate two 282 size O2 tanks. Problem is the OEM tank is in the way. I considered using only the curbside tank omitting the the other but this also leads to a lesser problem of the filler neck hanging directly in the way of the welding machine that is getting mounted on the curbside opposite the O2 tanks.
An after thought is to fabricate a tank to sit right behind the cab. I figured on going 6' wide (width of cab) 27" high (from top of frame rails to bottom of rear cab window) and 6" thick. This size will give me just around 45 gallons with plenty of air expansion space. In-tank OEM fuel pumps can be replaced with an aftermarket pump mounted under the hood or somewhere protected but easily accessed.
Only other option I came up with is to fabricate a tank to fill the curbside OEM location with a larger volume and filler located behind the welding machine closer to the rear axle. This would palce it under the flatbed section of the body allowing for more room to get fuel in. Volume on this tank will max around 25 gallons.
Third idea I had was to fab a thin flat tank to mount between the frame rails under the flatbed but the limitations of size end up giving this one barely 15 gallons storage.
I'm open to all suggestions here and appreciate all input. Thank you, Mark Kw
T_Bone
09-27-2003 09:43:44
 Re: Truck fuel tank? in reply to Mark Kw, 09-27-2003 07:21:20
Hi Mark,
Since your a business and probably licensed commerical plates, all fuel tanks have to be DOT approved if tied into the existing fuel system. I see even tranfer tanks need a DOT approval for commerical use. All the new tanks have roll over check valves and auto pump disconnect. I think the only time that would bite you in the arse, is an accident but if you have empolyees then you really have increased your libility. Just a thought!
That said, hard to beat behind the cab as you get the gallon capicity you want with a convient filler neck location,ie; behind a locked door. I measured a big rig truck nozzel at 1-3/8". I only use cold roll steel as that keeps steel flaking nill. Do not use any galvanize steel with diesel as it leachs zink into the fuel. A 1/2" diameter internal vent accross the tank width works well for filling.
What I did is keep my OEM tank. I then plumbed my Aux tank into two- 2 micron Racor filters then into the OEM tank where it gets filtered again by the engine filter. I made the OEM vent loop back to the aux tank incase I forget to turn off the tranfer pump. I put the vent to a electric solenoid to keep it closed and the dirt out when not tranfering fuel. I use a non-vented fuel cap.
Since diesel fuel by nature has entrained air, then I'm making the air leave the fuel to supply vent pressure or venting it's self. Air is not good in a injection system. Works on my system but may not on yours.
I never fill the OEM tank from the pump. This makes my fuel extremely clean and dry. The reason for the triple filter design, is I'm trying to increase my injector life span.
T_Bone
Mark Kw
09-27-2003 14:44:01
 Re: Re: Truck fuel tank? in reply to T_Bone, 09-27-2003 09:43:44
I saw where there are numerous notes as to connecting a skid tank to a vehicle system. I think I have room to argue here since the fabricated tank will be replacing the OEM tanks completely and be the only tank on the vehicle. I believe I have a little more wiggle room since only me and my wife will be driving the truck and it's a 1985 making it 18 years old, pre-dating many of the existing laws. I think you got my location a little wrong, the tank will not be inside the cab but directly behind it sitting on the frame. Taking note of the extrenal tank hanging off my 1980 GMC C-70, the only safety device on this one is the lead blow outs on the fuel cap. This one only has a small vent fitting on the center of the top w/ a piece of 1/4" CU tubing going to a vent cap screwed to the back of the cab. There is no impact/crash protection on this tank just as there is none on semitruck tanks. In application, the behind the cab fabricated tank for the pick-up would actually sit quite a bit higher than the the OEM one on the C-70. I do plan on making all the pipe connections over the top of the tank and using an OSV (oil safety valve) right at the tank so that if a line got knocked off fuel could not siphon, (OSV requires a vacuum to be present on the outlet side of it or it will not allow fuel to flow). Thanks for the tip on using cold rolled steel. I am considering using aluminum though.
T_Bone
09-27-2003 17:43:16
 Re: Re: Re: Truck fuel tank? in reply to Mark Kw, 09-27-2003 14:44:01
Hi Mark,
I really don't see a problem but I didn't know if you knew about the DOT thingy.
I was talking outside behind the cab with a outside locking door with the filler neck inside the box. Out of sight out of mind?
Most of the newer commerical tanks are using a vertical top suction tube to the bottom of the tank. Invert the tank and the suction tube is then in the air tank space and can not siphon on center placed tubes. They use a ball check valve on the discharge tube so if a tank gets upside down with the fuel line cut then a gravity check ball seals the suction line discharge. Refrigeration supply houses carry them for about $15.
T_Bone
Mark Kw
09-28-2003 07:30:41
 Re: Re: Re: Re: Truck fuel tank? in reply to T_Bone, 09-27-2003 17:43:16
Going to check into putting an inertia cut-off switch on the fuel pump too. Apparently these are very reasonable in price and it definitely does not hurt to put a little more safety into things.
RJ-AZ
09-27-2003 09:31:58
The later GM 6.2 ad 6.5 have a frame rail mounted electric fuel pump (looks like a fuel filter) on the drivers side. You might want to look for a suburbn tank. That goes behind the rear axle, 30 gal. I think. My work truck is a 1995 HD 3500 w/utility body and 6.5 diesel and has a tank behind the rear axle.
