Tool Talk Discussion Forum
What is a good used 5 ton dump truck???
Haulnredneck
09-26-2003 18:26:51
I am looking for a used 5 ton dump truck. So far my favorite I have found is a Chevy C70 with a Detroit diesel. What trucks hold up well? I had an International but I cant find another that isnt beat as bad as mine. I love the DT466. Is the Detroit gonna make me happier? Thanks.
Tractor Dan
09-28-2003 06:22:37
 Re: What is a good used 5 ton dump truck??? in reply to Haulnredneck, 09-26-2003 18:26:51
i know where there is a 85 or 86 ford l 8000 with 3208 turboed cat there is no dump body on it now but it was set up for a high way truck so its got a good live hyd pump and the truck isnt in bad shape email me and ill get you the guys phone number
haulnredneck
09-28-2003 06:02:38
thanks for all the great replies. this guy is getting dirt cheap on this chevy. i think i am gonna try it!!! i am gonna rebuild my international now that i can park it for awhile. this chevy is non commercial and the original owner has only racked up 43,000 miles. it has air brakes and great tires. has to be worth the $3000 he will take. i just cant find any better deals right now and i gotta get to work. thanks.
george md
09-28-2003 20:53:48
 Re: Re: What is a good used 5 ton dump truck??? in reply to haulnredneck, 09-28-2003 06:02:38
You are a slower learner than most of us gave you
credit for . If that is a 4-53 T made in brazil
and you have to work on it , that will be the
most expensive 3000 dollars you ever spent.
george
Jeff
09-27-2003 21:16:25
I bought a 5 yard dumper from our state.
DT466 with an Automatic.
Love it.
Paul Janke
09-27-2003 20:56:35
I have heard it said that Detroits are the only externally lubricated engine on the market. They start easy and have a reputation for lasting better when used hard.
JD790
09-27-2003 10:34:54
I would run from the C_70 with the Jimmy.
Another IHC with a Dt466 or a Ford L Series with a 8.3 Cummins or The Ford inline diesel.
With Some Old Ford L Series they Are getting harder to find some New Cab components.
mom
09-27-2003 05:56:41
other than some noise you can't beat an old detroit deisel they'll run forever and take abuse like nothing else out there the only time you have to worry about them is when they aren't leaking a little oil
F14
09-27-2003 04:18:58
My reputation is gonna be in tatters after this, but I'd recommend looking for a Ford, preferably with the Ford diesel in it. About 90% of all the older dumpers around here are Fords, as are most of the oil trucks.
Our fire department bought a Ford oil truck chassis, an L800(?) with about 120K miles on it, Ford turbo diesel and a 6 speed. After tires, shocks, some steering parts and a paint job, it's now our water tender, and it's a workhorse, runs like a top, and hauls 1800 gallons (roughly 7 and a half tons) of water like it ain't even there.
gatractorman
09-27-2003 02:13:11
The C-70 is probably gonna have an 8.2 litre V-8 Detroit and you do not want that, you will long for your beat up Int. with the DT466.
JOHN (LA)
09-26-2003 20:13:54
While if it were a 2000 model truck I would say Detroit motors are OK. They have cleaned up there act a lot. The older Detroit's are a joke. I have NEVER seen, drove, or heard about a truck with a Detroit that did not have a big oil spot under it.
chris
09-26-2003 18:46:27
RUN!!!!! from the detroit.
