Tool Talk Discussion Forum
Preventing rust inside an LPG tank
Darren in TN
09-25-2003 12:46:41
Howdy, all.
Several of you had gret replies when I asked where to get a replacement tank for my compressor for a good price. I'm thinking seriously about hooking it up to an unused LPG tank, but now I'm worried about preventing rust in the tank. Anyone ever have trouble with these rusting out? Should I treat the inside somehow? I'm asking because I know you guys have a wealth of knowledge in these things and the last thing I want is a 100# bottle coming apart at 125psi in my shop!
Thanks again,
Darren
Andy
09-25-2003 18:23:55
 Re: Preventing rust inside an LPG tank in reply to Darren in TN, 09-25-2003 12:46:41
As far as finding a good tank, I think any used one would be fine. LP tanks don't have rust problems on the inside. It is a tightly controled product. Once you make a compressor out of it, it's like anything else,(other than stainless or alum.
Bus Driver
09-25-2003 16:21:26
How coincidental that this question should come up now. About 30 years ago, I was given a junked (twice) 100# propane bottle. The boss for the valve had been mutilated with a torch- probably by the gas company. The tank was then set up beside the road and advertised the refilling services at a large mobile home park. Open to the weather when used a sign. I welded a new fitting in the end, welded a few pinholes rusted through on the bottom from sitting on the ground. Doubting the integrity of the tank, it was stood upright, filled completely with water, then fitted with a high pressure gauge and a grease fitting. Raised the pessure with a grease gun. One of the fittings cracked at 4210 PSI. I deemed the tank OK. Mounted old belt driven refrigeration compressor and 1/2HP motor, pressure switch, safety popoff, 2 quick connects. Good unit, tank is about 30 gallons. Too heavy to be called portable, slow to build pressure- but affordable and very useful. Then got big compressor for the shop. About 5 years ago, startd to use the homemade rig and the tank was leaking at the bottom (originally the side_- hole in tank. Bought another propane bottle as a replacement- but never changed to it. This week, desperately and quickly needed it at another location, so removed the compressor, turned the thing over- the hole was just a pinhole- solid metal around the hole- carefully verified. Ground off the area clean, welded up with MIG. Quick tested to 175 with big compressor. Now back in service at 125 PSI. I am convinced that it is safe. So a clean propane bottle will last a long time. If in doubt, pour in about a quart of Rustoleum, put a plug in the hole, rotate it for a while- and also every day for a while. After about a week, pour out the paint that is still liquid. Leave the plug out for a few days.
One more thing, I did put a drain petcock in the bottom- actually the side- before testing the first time.
