Tool Talk Discussion Forum
Craftsman Riding Mower Problem
Steve B.
09-25-2003 10:11:23
I have a Craftsman riding mower that is having a problem. It is approximately a year 2000 model with hydro transmission. The engine starts fine, but when I take my foot off the brake the engine stops. Any ideas?
Thanks.
AZ Jack
09-25-2003 20:14:29
 Re: Craftsman Riding Mower Problem in reply to Steve B., 09-25-2003 10:11:23
Just went thru this with my Sears hydro. Hydro is not a problem. It is probably the seat interlock that is bad. Call Sears hotline-the # should be on your tractor somewhere. They can tell you what they think it might be. They may tell you your tractor is out of warranty, however tell them to go to H--l, this is a safety problem and is a very common problem with their lawn tractors. Jack
Mac
09-25-2003 10:56:31
Sounds like you have a safety switch problem here.
You can take a small wire and jump each switch individually by unplugging harness and jumping there. see if this solves the problem, if so, switch is either broken, rusted up or corroded internally. Jumping is not a pemanent fix, only do this as a test method only. A safety issue is involved.
