Tool Talk Discussion Forum
Stupid Question- Poulan XXV Chainsaw
Richie MaGoo
09-24-2003 17:18:03
Hey Guys!
Someone gave me an old Poulan XXV Micro chain saw- I put in a new spark plug, and some ether, and after about 10 pulls, got her to run for a few secs but only once- can't get her to start again. My next step is to clean the points.
Problem: I'm new to chain saws, and dont know where the points are or how to get at them (my guess: either under the starter pulley or under the chain sprocket)
I might even go so far as to replace the condenser if I must- but i dont want to put a lot of money into an old saw that may not even be any good- any suggestions (written "for dummies" style) appreciated- and please....where are the points?
Thanks in advance,
Rich
Poulan
09-25-2003 14:14:45
 Re: Stupid Question- Poulan XXV Chainsaw in reply to Richie MaGoo, 09-24-2003 17:18:03
Try the following Poulan website for a copy of the manual.
fearless
11-05-2004 07:19:28
 Re: Re: Stupid Question- Poulan XXV Chainsaw in reply to Poulan, 09-25-2003 14:14:45
Just wondering if you managed to get the Micro XXV chainsaw going. I have same model and similar symptons. Problem in this scase is carby and now I am trying to obtain carby kit for Walbro carby. Anyone have any ideas? By the way, I managed to get a service manual for this - but not from the Poulan website.
Richie MaGoo
09-25-2003 11:01:57
Thanks guys. But spark is definitely the problem (or...uh...at least the main problem!)- she won't even run with ether sprayed directly into the cylinder (escept for that one brief time)....and I do smell fuel after several pulls.
Any idea where I could find info, such as point gap, etc. (I gapped the plug to .025 hope it's right!)
bob missouri
09-25-2003 18:36:20
 Re: Re: Stupid Question- Poulan XXV Chainsaw in reply to Richie MaGoo, 09-25-2003 11:01:57
try a compression check first before sinking money into it. if it doesn't have enough compression no sense going any farther.
John in MA
09-25-2003 10:25:12
The points are under the flywheel.
Before you mess with those, rebuild the carb. These saws are getting on in years and will need it even if it's not the main problem.
treeboy
09-24-2003 17:52:17
my guess , carb problem from old fuel left in saw prior to your ownership, try putting some fuel in the muffler & pulling the starter( if it fires & runs out of fuel it's NOT points)
DaveCA
09-25-2003 05:35:41
 Re: Re: Stupid Question- Poulan XXV Chainsaw in reply to treeboy, 09-24-2003 17:52:17
I agree with Treeboy, most likely not getting any fuel. The spark plug should be getting wet with no spark, if it's flooded with fuel or bad fuel. Just take the plug out and look at it right after trying to start it a few pulls. If it's staying dry and you can't smell fuel on it or from exhaust, it's not getting fuel.
