Tool Talk Discussion Forum
What does duty cycle actually mean?
Lee
09-24-2003 08:42:32
In a welder, what does duty cycle actually mean? Would a 20% duty cycle be 20% of an hour (12 minutes continious welding) or 20% of a minute (12 seconds continious welding), or what?
This may sound like a stupid question, but I have an old stick welder I use around my place a lot, but mostly for little jobs (maybe 5-10 minutes at a stretch) so I've never worried about duty cycle -- should I???
Thanks.
Lee
TimV
09-24-2003 11:16:49
 Re: What does duty cycle actually mean? in reply to Lee, 09-24-2003 08:42:32
Lee: One other important note: duty cycle is rated at a specific amperage. If a machine is rated for 20% duty cycle at 225 amps, it might weld all day long at 50 amps with no overheating. A welder is like most other tools--you're wise to size your purchase so that the intended use falls into the middle (roughly) of its capabilities. That way you don't spend more than you need to on a over-sized machine, and you don't run into the constant frustration of trying to make a piece of equipment routinely perform beyond its design limits.
T_Bone
09-24-2003 09:21:02
Hi Lee,
Duty cycle is based on 10 minutes for USA built machines. Some forgien machines are based on 5 min rating.
So a 20% machine would be 2 minutes welding and 8 min rest in a 10 mintue period.
Over the years I have used machines that when they get close to there duty cycle end, the arc will drop off, or stutter, before they trip on the reset, that is if they have a auto-reset.
When I see the arc stutter, I quit welding for a hour as it's very hard on the machine. Most cool faster if they have a fan and you leave them on. If no fan then shutt them off.
T_Bone
