Tool Talk Discussion Forum
OT: Burn Barrel?
Rod MI
09-24-2003 08:33:34
Hi I have to make a new burn barrel. Where is the best place to put the vent holes and how many do I need THANKS
Rod MI
09-26-2003 08:06:20
 Re: OT: Burn Barrel? in reply to Rod MI, 09-24-2003 08:33:34
Thanks everyone!
h
09-24-2003 23:11:16
I wack the sides of a new burn barrel with a sharp long handle pickaxe I have. Though I do not count the holes, I probably put in about 20 or 30, in the lower 2/3 of the barrel. This seems to give pleanty of air for an efficient burn.
I have always put the ashes in hole I am trying to fill, mostly because I am worried about nails from junk wood I sometimes burn. So I only put a small drain hole in the barrel bottom and move the whole barrel to the hole with the tractor loader. The suggestions about setting things up so the wind can blow the ashes away interest me, but maybe this area is generally too dry for that to be safe. I have a square of 1/4" steel plate that I put over the barrel if wind comes up when I am burning or to keep rain or snow out. The steel will not put out the fire, but it will control it pretty well, if need be.
Burning is not technically legal in my area, but most people do it to some degree and the law is not enforced. But GOD HELP YOU if you are burning and the fire gets away from you. I have not started my barrel since July, and will probably not use it until mid October unless we really get some good moisture before that. Stuff is piling up..... Good luck, be safe!
ted
09-24-2003 19:04:28
I used some larger old u shaped corn cages. weld the 2 together to make a circle, then another set to make it tall enough. Works great! Plenty of air and the wire spacing is good enough to let the ash blow away. Best part that it comes made pre-galvanized and will last for years even after the galvanize is burnt off (1/4" thick wire i think).
Have fun
RayP(MI)
09-24-2003 18:22:05
I used a .44 Magnum. Be sure to use earplugs under your gun mufflers! A couple holes in the bottom for drainage, and 5 or 6 a couple inches above the bottom around the base ought to be sufficient. A pick axe or a screw driver and a hammer will suffice, but not near as much fun!
MGM
09-24-2003 15:17:16
I know this sounds funny but I got out my 22 pistol and had some fun, puts lots of holes all the way around about a foot high and of course seepage hole in the bottom, its fast and do it safe, with no kids around.
I do agree with the other guys too.!!
Mike
toolman
09-24-2003 17:40:44
 Re: Re: OT: Burn Barrel? in reply to MGM, 09-24-2003 15:17:16
i remember a fellow was putting in a well using a 20 ft culvert,needed to put a bunch of holes in the bottom 10 ft,he was shooting it with a 22 got tired hung a no shooting sign on it went back to town came out a week later to put the well in, culvert was riddled with bullet holes ,many more than he wanted haha.
TimV
09-24-2003 13:02:40
Rod: Standard practice is to put 4 holes about 1" diameter equally spaced about 2" from the bottom of the barrel. You may also want to drill a few holes 1/4" or thereabouts in the bottom of the barrel for water drainage. Set the barrel on cinder blocks (eye-to-the-sky) and burn away (following all federal, state, and local regulations, of course.....)
T_Bone
09-24-2003 09:07:24
Hi rod,
What I did was to cut the bottom out leaving 1" all around from the edge. I then welded another barrel to the top of that one, no 1" lip on the mid joint.
Then I sit the barrels on cinder blocks with a old refrigerator grate in the bottom on top of a center cinder block. This keeps the grate from sagging down after becoming too hot. Re-bar would also work well.
When the trash gets done, there's nothing but ash left over and the wind will blow that away. There is never any part of unburned trash left over nor does the smoke stink like trash burning. I hate that smell.
Caution:
If you add to much trash at one time, I can shoot flames 5ft above the top barrel and the barrel sides are cherry red.
T_Bone
Dick
09-24-2003 15:21:02
 Re: Re: OT: Burn Barrel? in reply to T_Bone, 09-24-2003 09:07:24
Rod -
I did mine somewhat like T-Bone's. I used one 55 gallon drum. Cut one end out, leaving a 2 inch rim around the flat bottom, then got a piece of expanded metal that is one inch larger in diameter than the hole and an inch smaller than diameter of the bottom. Set the whole thing of on a couple of bricks. Burns like a blow torch by drawing air up through the bottom. Like T-Bone said, very little ash, that blows away, and no rust.
Try it, you'll like it.
Dick
ShepFL
09-25-2003 08:04:25
 Re: Re: Re: OT: Burn Barrel? in reply to Dick, 09-24-2003 15:21:02
Ditto to Dick's comments except I have no rim on either side. Barrels tend to last alot longer than putting holes in the sides. That configuration tends to rot out bottom of 1/3 of the barrels due to repeated cycles of heat accumulation and moisture (rain on unburned trash).
Jay
09-24-2003 15:49:15
I did this same thing except with a culvert - I welded rebar across the bottom every 2 to 3 inches. Put it on some blocks. It burns like crazy, don't rust, and is heavy enough to stand up in the wind. Oh, and no debris.
I used a 2 foot culvert.
