Tool Talk Discussion Forum
gas cans
rwh
09-21-2003 19:16:45
Got a good deal on some steel gas cans at an auction. One had gas in it; the other two diesel or maybe two-stroke fuel. I want to put gas in them and figure if I leave them open and upside down for several days, the diesel should evaporate and I should be good to go. Any fallacy in that thinking?
JOHN (LA)
09-21-2003 20:18:43
 Re: gas cans in reply to rwh, 09-21-2003 19:16:45
A little bit of a different product will not hurt. A Little diesel will just lube the valves and be burned off.
You get a little diesel most every time you buy gas. The delivery truck hauls a load of diesel to a truck stop then goes and gets the gas for your station. He does not wash out! All ways a little left in the truck.
Now if it is water I would try to get as much out as you can.
ChrisL
09-21-2003 19:18:31
a little diesel fuel in gas is no problem - it is worse the other way - getting gas in your diesel - water is the worse problem -
