Tool Talk Discussion Forum
VICTOR METALPOWER TORCH KIT ON LP?
Rod MI
09-20-2003 21:31:04
Hi I'm looking into buying a Victor torch set from HF. I wont it for brazing and cutting using LP gas. Dues anyone now if the gages will hook up to a LP tanks and a standard 80cub Oxy tank(what size are the valves?). Is the hose rated for LP? can I use the welding tips with this kit for brazing with LP? Can I get A LP cutting tip for the cutting head? I'm just sick of looking for information on the different sets sow I'm posting my frustration on this board Thanks for any help
Kennyp
09-21-2003 12:51:40
 Re: VICTOR METALPOWER TORCH KIT ON LP? in reply to Rod MI, 09-20-2003 21:31:04
I have been using LP, oxygen for the last 30 years. Yes the acetilene (sp?) gauge is the same thread and works fine with LP. Just hook it up an go, BUT--the tips will not work with satisfaction. Go to a welding supplier and get a cutting tip for LP. If you buy a standard brand torch, they should be able to order you one. I use the cutting tip for brazing and like it-LP- better because it does not get hot enough to melt the steel. For cutting, takes longer to get hot/started but leaves a cleaner cut. I have just one tip, but sugest you get two, one a little larger.
Rod MI
09-22-2003 10:39:53
 Re: Re: VICTOR METALPOWER TORCH KIT ON LP? in reply to Kennyp, 09-21-2003 12:51:40
THANKS!
Rod MI
09-20-2003 21:33:26
LINK
