I think the way you phrased your question confused some folks. "A completely equipped shop" is pretty open ended, and you can easily spend 10 times your budget, as folks stated below. "Enough tools to rebuild an old tractor" is a whole other situation. If you shop carefully, you should be able to get pretty well set up for $1500. A good selection of sockets and hand wrenches is obviously critical. I just started as a mechanic at an equipment rental place, and took most of my tools to work. I've been restocking the home toolbox by shopping at Walmart and Home Depot. Don't laugh, you can get some good tools at Walmart at decent prices. I've gotten good sets of 3/8 and 1/2 drive Stanley sockets both standard and metric in deep well and regular, with ratchets and extensions, and spent less than $100, by catching them on sale. You can save a few bucks by starting with the 1/2" sockets only. You'll need the heavier ones, the 3/8 are lighter and easier to use, but except on rare occasions where access is a problem, you can do everything with the 1/2". A long flex bar is handy for the really tight fasteners. 2 foot minimum, 3 foot is better. Good combination wrenches, preferably 2 sets so you have one for the bolt and one for the nut when needed. Stanley or Husky are decent quality and very reasonable. A good set of screwdrivers. Again, Stanley. Vise grips in a couple of sizes A GOOD adjustable wrench. No K Mart stuff here, you need to be able to put some grunt behind it without it slipping. An impact wrench. If you can work in an air compressor get an air drive, if not, a good electric will do a lot of work for you. Center punch, pin punches, drift punches, a big brass punch, a big ball pein or 3 pound machinists hammer. An oxy/acetylene torch is darn near indispensable, but expensive. You should be able to get most of that for your $1500 easily enough. Until your budget improves you can rent cherry pickers and engine stands and such. Good luck, and have fun!
