Tool Talk Discussion Forum
Darn thing won't crank
Mitch
09-18-2003 19:23:47
I have a 12.5/38" DECK MTD Lawn Tractor. I put in a new battery and a new spark plug,(a full tank of gas, too), but it won't crank. There is a knocking sound just under the ignition when I turn the key. This has happened before and all I had to do was jiggle the handle that engages the deck--THEN it would crank right up. Now, that little trick won't work! What could be the problem? I appreciate your help!!
Mitch
Paul Janke
09-20-2003 07:45:20
 Re: Darn thing won't crank in reply to Mitch, 09-18-2003 19:23:47
I would guess there is a bad connection on a battery cable. It could be either end of either cable.
JOHN (LA)
09-19-2003 08:20:07
Same thing happened to my sears. The starter solenoid is on the inner wall under my switch. If I giggle the blade engagement lever it would crank. What I was doing was shaking the solenoid in a round about way. drove me crazy. Check yours it may be the same.
Hermit
09-18-2003 19:50:41
If you could make it work by jiggling the deck handle, it sounds like one of the safety switches went bad, possibly the wiring around the switch loose or broken.
