I just bought my first air compressor a few months ago, It's a 6 hp, 150 PSI, 30 gal vertical tank, oil free Sears that is, in fact, currently on sale. At the present, I don't use it very often - maybe once or twice a week - but with various projects coming along, will be using it more.My question is, between uses, what's the best way to leave it: shut it off and bleed off the pressure, shut it off and leave it pressurized, or leave it on to maintain pressure? I'd like to do whatever I can to keep it in good condition. Our climate is dry, but even so, I notice that when I bleed it using the draincock at the bottom, a little moisture comes out. I have been bleeding it unless I know I'll be using it the next day. I bleed with the pressure relief until pressure gets low enough that it won't stay open without holding it open, then open the draincock. The moisture that comes out isn't much, but enough to leave a damp spot under the draincock where the air hits the concrete floor, and to tell that it is just a little discolored form light rust? Even though it's "oilfree" should I be oiling somewhere? Another comment and question - I have noticed that when I open the draincock, as the pressure gets down, it sputters, and somtimes stops bleeding without bleeding all the way down. Yesterday when I used it, I noticed that when I closed the draincock, it didn't shut all the way off. When I finished the work I was using it for, I pulled the draincock and noticed that the o-ring on it was chewed up - probably what was sputtering and probably the cause of the leak that wouldn't let me shut it off all the way. Is this a result of opening and closing it too often? I'll be getting a new o-ring, or if I can't find one, a new draincock, but I'd also like to prevent this from happening again.
