Tool Talk Discussion Forum
JD 350 winch
Bernard le m�ca
09-16-2003 15:02:37
Hi, I own a winch, from a 350 Jd crawler. I use this winch for logging tree with my farm tractor.The internal pump was worn and i have problem when i try to pull the cable, the drum brake don't loose enough. Can i run the pressure from the remote of my tractor?Is the winch have a pressure regulator? How the pressure and GPM can i use to operate the winch? Thank you! Bernard le m�cano Qu�bec Canada
treeboy
09-17-2003 18:33:53
 Re: JD 350 winch in reply to Bernard le m�cano, 09-16-2003 15:02:37
call a local logger, those da-- winches were hard to get adjusted just right, but they sure do pull.
you'al have to find some one with a 350 or 450 jd dozer
RJ-Az
09-17-2003 20:14:43
 Re: Re: JD 350 winch in reply to treeboy, 09-17-2003 18:33:53
You should be able to plumb that winch into your tractors remotes and work OK. GPM and PSI were pretty close in specs.
