Tool Talk Discussion Forum
seeping cast iron water furnace
paul
09-15-2003 07:43:36
Well it was a little chilly this morning so I fired up the oil burning furnace (water circulating, not forced air) to see if things worked ok, so I know before I _need_ it. Worked fine.
However I have an old cast iron Crane wood burner plumbed in with it, and there is water oozing out of a 1" area on the top front of the water jacket.
This is all fairly low pressure, 14# is what I should run I believe, no more than 20#.
Anything I can do, or is it done & over? I'll figure welding is out, but any of the JB type products work, or not worth trying - pressure & heat too much. Welding doesn't sound good, thin jacket, I can't weld, heat & expansion....
Kinda bummed, was laying in more wood with the price of fuel going up, & now this. Any good water jacket furnace models out there????
--->Paul
T_Bone
09-16-2003 14:47:11
 Re: seeping cast iron water furnace in reply to paul, 09-15-2003 07:43:36
Hi Paul,
I've been thinking about your leak. If you make any temp repair then one day when you awake your livingroom will be flooded.
How about trading labor with a known good weldor in your area? You would then be pretty assured it's going to last awhile. Epoxy seals well from the pressure side but poor from the structual side or seals best from the inside.
The weep is probably on a elbow or close to a change in water direction and if thats true then most likely theres a larger area that needs repaired that you can't see.
Since it's a low pressure system, simular too a engine radaitor, then a repair might last awhile.
Gas welding works best as it also stress relieves the base metal as it's welded.
T_Bone
paul
09-18-2003 05:25:12
 Re: Re: seeping cast iron water furnace in reply to T_Bone, 09-16-2003 14:47:11
I'm thinking about it too..... ;)
This is a cast iron water jacket. The weeping crack is on the top front outside of the furnace. It would be above the heat chamber (smoke chamber?). The furnace has the fire chamber, smoke goes up the rear, horizontally to the front, up again, and horizontally back to the chimney again. All of these parts are water jacketed, the funace is in seperate vertical sections, held together with long bolts - like an old cast radiator. The crack is in the section that is the front, with the doors & all. This is a rather large furnace - it can hold 27" wood, 9" across. A friend of mine joking suggested _taking_ the furnace to a weld shop! :)
Anyhow, how fragil is a water jacket to weld on? Not going to fit this piece in an oven to heat. :) I would think the uneven heating of a welder would just shatter the whole shell, and difficult (impossible?) to heat all sides of this.
Seems like welding would induce more cracking, but I'm not a metal guy.
--->Paul
Dusty
09-15-2003 17:14:43
Sometimes things weep when they are cold, once they are warmed up they stop.
Good Luck,
Dusty
ATW/WA
09-15-2003 16:49:25
Paul, Is this inside the fire box? If you check automotive stores they have high temp epoxy for exhaust systems. Inside the fire box, the wall temp should only be a little higher temp than your hot water. Now for ths hard dart, anything over 15PSI is considered a pressure boiler and subject to regulations of the National Boiler Safety..BLAH, BLAH ,BLAH.....
A catastrophic failure of any repair job could compromise any insurance coverage.. LIABILITY...
bummer!!!
I bet your system is no higher than 14psi, getting rid of all those worries.
I would be concerned about the integerity of the entire "Old cast iron Crane wood burning system". If it is truely old they over designed for safety and longivity of systems. Any leakage could be indicative of future system failure. Is it water chemistry or end of expected full life of the boiler. Will component replacement correct the furnance for future generations to come?
Can you isolate and by pass this unit for repair, if the patch does fail in the middle of a cold snap?
Your furnance your call.
ATW/WA
paul
09-16-2003 08:38:38
 Re: Re: seeping cast iron water furnace in reply to ATW/WA , 09-15-2003 16:49:25
Thanks all. I'll guess it's 14# psi also then, think it runs at 11 most of the time.
It is outside, top front of the furnace, a 1" weeping crack. No evidence of it ever before, when I fired up the oil burner (which heats up the water in the wood burner as well) suddenly it was damp or seeping there on the wood burner, stays that way when cold.
My concern also is long term, what is the condition of the whole unit? Dad got it used 30 years ago, nice wood furnace, but how old, how beat up? We run cistern water (roof collected) in it.
The oil burner has a pump, but the wood furnace is self circulating.
While the valves are very old, 4 of the big fellas will isolate the wood furnace.
I will talk to my furnace guy, but figure on trying an epoxy for this year maybe. See how it goes anyhow. Won't be able to find as good a unit a unit again!
--->Paul
other bob
09-18-2003 06:26:08
 Re: Re: Re: seeping cast iron water furnace in reply to paul, 09-16-2003 08:38:38
not saying it will work but have taken a prick punch and peened along leak.
jake
09-18-2003 20:35:35
 Re: Re: Re: Re: seeping cast iron water furnace in reply to other bob, 09-18-2003 06:26:08
My Dad was a plumber-boiler man in the 50's and would repair cracked boilers by putting flaxseed in the system. It was a fast and effective fix.
VaTom
09-15-2003 15:13:40
Paul,
Planning a trip down our way soon? I have a surplus wood fired boiler that turned out to be too large for my use. Takes 4' logs.
There are several companies that make them, just fatten your wallet. Easy to spend $5k uninstalled.
Bob
09-15-2003 10:34:38
http://www.silverkingmfg.com/safe.htm
Bob
09-15-2003 09:15:42
If it's leaking in one spot, it's probably not going to be too much longer before it's leaking in many spots. I'd consider replacement.
JMS/MN
09-15-2003 07:56:59
Wouldn't the JB weld work? If people use it to close engine block cracks shouldn't it handle the heat of the water jacket?
