Tool Talk Discussion Forum
Log splitter parts
Phil
09-14-2003 12:00:43
I'm looking to try and build a splitter "on the cheap" Gettin tired of borrowing a friends. Does anyone have any parts the can get rid of cheap? Im lookin for a control valve, pump,and hyd cylinder. Yeah I know all the important parts. thanks, Phil
treeboy
09-16-2003 18:27:29
 Re: Log splitter parts in reply to Phil, 09-14-2003 12:00:43
get a two stage pumpo.. period,,, put a inline filter also (northern hyd)
TimV
09-16-2003 06:01:09
Phil: Saunter around the local "auto recycling center"--there's more hydraulic parts out there than most people realize. Depending on your proposed setup (and your level of fabricating skill) you can use parts off from old snowplow setups, dump truck lifts, hydraulic tailgates, etc. etc. etc. I've seen some very well-built log splitters with not a single "new" part on them.
Phil
09-15-2003 12:07:44
I'm in eastern IA. Zip 52213
Also does anyone know if the Hyd system on my MM-335 would put out enough pressure and flow to work for a splitter?
Paul Janke
09-15-2003 17:42:36
 Re: Re: Log splitter parts in reply to Phil, 09-15-2003 12:07:44
The force of the splitter is a function of the cylinder size and system pressure. The speed of the splitter depends on the size of the cylinder and the pump flow rate. The bigger diameter cylinder is slower but has a higher force. The kind of wood you are splitting as well as its length and diameter will also affect what you need. I think that a 1500 PSI system would do a decent job if the cylinder chosen is of adequate diameter. We have only evergreens here for firewood, but my 3 1/2" cylinder at 1500 PSI did a good job on 16" lengths of up to about 2' diameter for most of the wood. Bad knots could be a problem. Another thing that helped tremendously was an arm we built to use the cylinder to pull the blocks back off the wedge which had refused to split.
Paul Janke
09-14-2003 19:33:12
Where are you? Shipping can be considerable.
