Super A Man
09-14-2003 18:54:05
Re: Re: OT: motor swap 88 suburban in reply to iceman, 09-13-2003 06:31:54
How does it run at idle? On a friend's 90 GMC he trew about all the replacement sensors, egr, etc. at it until he found a metering spring in the throttle body was broken. I can't remember what it's called, but that fixed the problem. They seem to be universal, cause we borrowed on from a blazer v-6 throttle body to fix it. His engine also had poor low end power, but it idled horribly. Just about had to keep pressue on the gas pedal to keep it running. If you are determined to switch engines. I agree with the others stay with FI if it's a daily driver. Otherwise you will have to disconnect all the computer stuff and run it with 1970's technology. Change distributor to HEI with vaccum advance, and no computer lead. It will work, but TBI is better for everyday use, and you don't have to buy as many parts to make the change. One word of warning, if you do get a crate engine or replacement engine from what ever source, and stay with TBI, make absolutely sure it is an 1987 or newer engine, or at least the heads are 1987 and up. The older blocks are generally the same, except for the two piece rear main seal on the old ones and 1 piece on the new. But if you've got an 85 or older heads, intake bolts in the center are angled different, and an 88 TBI manifold will not bolt up. also in 1987 they changed to the center bolt valve cover rather than the ones with 4 bolts on the edges. Sorry for the long post, just trying to give some good info. I'm not an expert, but I've worked on switched out, etc. a lot of small block Chevy engines, and ran into a few things here and there. If I can give you any other help, email me. Kevin
