Tool Talk Discussion Forum
log splitter not splitting well anymore
tomj
09-08-2003 06:46:22
Ive got a 5hp 20 ton "Brave" log splitter. Up until recently it has split large oak logs with no problem. Now it seems to be having difficulty splitting larger(18"+) logs. I can help it by starting a split with a mall or an axe while I have the pressure on the log, but I never had to do this before. If I aim all splits directly to the pith of the log it helps a lot, but, as I said before, I never had to do this before. I bought this thing used several years ago and have no instruction manual.
What could this be? The logs I split before were downed trees that had been on the ground for over a year but not cut up . The logs I'm cutting now were just cut.
Matthew
09-10-2003 12:07:25
 Re: log splitter not splitting well anymore in reply to tomj, 09-08-2003 06:46:22
I believe that your seals have gone out in the cyclinder. This will happen if it has not been used in a long time. They dry up and then when you try to use the splitter, the seal just breaks apart and remains in the cyclinder. This could be a possibilty of why it will not split some logs. Without the seal there is enough pressure for a lot of wood but not near enough for the big wet logs.
MarkB
09-08-2003 18:56:42
I have one of these splitters (I think it's 24 ton), and it splits anything I can get up to it. I routinely split green oak over 24" dia.
I suspect that the pump is shot, although it could be other things as well (eg. cylinder). Northern Tool carries replacement pumps. Look for the Barnes two-stage pump that matches yours.
I assume you've replaced the filter.
The Brave manual isn't of much use, BTW.
Joe (Wa)
09-08-2003 19:18:17
 Re: Re: log splitter not splitting well anymore in reply to MarkB, 09-08-2003 18:56:42
I agree with Mark. I have a 24 ton splitter also with the Barns 2 stage pump driven by a little 5 hp BS engine. I haven't found anything it won't split PDQ.
Trevor
09-08-2003 10:13:17
I agree with Shep and Fred.
Green oak can split mean and stringy. We have a tractor mounted splitter and we sometimes have to "persuade" it with the axe when splitting.
And with a small motor splitter I would definetly have a pressure gauge but make sure to protect it. Don't know bout you but we have a tendencey to break things when doing wood and a glass gauge wouldn't last long.
Let us know what you find out. Always good to hear if we were wrong or right.
ralph
09-08-2003 08:23:27
change the hyd. oil and filter see if that helps. ralph
Fred OH
09-08-2003 07:07:56
For about $20 you can put a 5000# liquid filled gage on it...plumbed in on the pressure side to tell if it (the pump) is working okay...mine split most wood at around 700#s pressure on the gage. Some of the control levers have an adjustment for setting the maximum pressure. A gage would let you check this also. L8R....Fred OH
ShepFL
09-08-2003 06:53:15
Sounds like to me you are splitting "green" wood and your splitter may not have enough "umph" to get thru it.
The other wood you spoke of sate for a yr. so a large percentage of the moisture evaporated allowing it to split. Consider finding some of the same "seasoned" wood or let the "green" wood sit until "seasoned."
FWIW
