Old weedeater needs help
David Leal
06-14-2000 14:16:38
I got a xt20 weedeater and the line trimmer has been completely destroyed. But the motor is great! What I would like to do is put one of those replaceable plastic blade. Does anyone know where I can get one from?
Nathan(GA)
06-15-2000 19:45:10
 Re: old weedeater needs help in reply to David Leal, 06-14-2000 14:16:38
They are usually sold everywhere that weedeater supplies are. Just be careful with them. I saw on the news last week where a little girl was killed by one of the blades coming off. Not sure, it could of been one with the metal blades. I think they said something about a recall.
Dan from PA
06-14-2000 18:54:54
I've had better luck with a spool of really heavy trimmer string. You can get it in up to a .135" size, and it seems to last forever, even trimming around junk piles with periodic run-ins with sheet metal. You may need to enlarge the holes in your spool, or, if you have the kind with the eyelets, get the right size.
F14
06-14-2000 15:13:21
If you mean what I think you do, check Walmart. This is the Ronco kinda thing with the hinged plastic cutters, right?
