Tool Talk Discussion Forum
Way O.T., lawn mower
kyhayman
09-07-2003 14:55:38
This is way off topic but I am puzzled and know there is a wealth of knowledge on this board. I have a 6 year old Murray riding mower, 46" cut, 17.5 hp Briggs. It will only run with the choke closed (and then pretty sick b/c the choke is closed). Plugs look good, plenty of gas, fuel and air filters are clean. Any ideas?
kyhayman
09-09-2003 19:03:17
 Re: Way O.T., lawn mower in reply to kyhayman, 09-07-2003 14:55:38
Thanks for all the good ideas. I have drained the carb already and it didn't help. Got an older gentleman here (my definition of that is older than my dad who is 79) who loves to work on small engines, I'm a big diesel guy myself. Gave him the $$ for a carb and fuel pump kit, will try both of those. Between trying to plant wheat and cutting fall hay plus I'm in the middle of 14 straight 12's at work this week I think I will defer to his experience on putting them in. Maybe by next Tue I can start cutting hay and my grass again. I'll post the results, thanks again!
TimC
09-09-2003 12:00:38
Either the little flappers are in bad shape in the fuel pump on the side of the carb or you have a vacume leak between the carb and the head.
Richard
09-09-2003 03:44:52
The carb on this engine is terrible about trapping water and starving for fuel. Pull the top off the carb and blow it out real good a reassemble, or clean the carb and install a kit. Normal condensation is enough to cause this problem, or the little plastic center covering the vent hole on the gas cap will cause moisture to enter the system. Let us know what you find. BTW, there is a way to drain the fuel on the bottom of the carb. but you will not get all the water out!
JoeK
09-08-2003 06:59:22
My old Murray 12/18 have both suffered similar problem.They are equipped with a pulse operated fuel pump,because of rear tank mounting.Diaphram kit is available from Briggs.12 has pump mounted on shroud,18 has pump as part of carb.Not hard/expensive to rebuild,just take your time.
This could well be your problem.OR you may just have a loose pulse hose connection/cracked hose.
ben
09-08-2003 05:08:14
sound like your carburetor is no good. Usually when a gas unit has to run with choke closed its a carburetor problem.
Good luck
PS. make sure you use gas stablizer in your fuel at all times.
Hermit
09-07-2003 18:21:41
You might want to try the garden tractor forum on this website for more expert advice but it sounds like there might be debris in the bottom of the gas tank blocking the gas outlet or debris caught in the fuel line from the gas tank to the carb.
